Would you post a picture of your loco ash facility?
Hi!
I’m fixin to design an ash facility (HO) that will handle two tracks (plus an ash removal track). I would greatly appreciate seeing what you all have - and hopefully it won’t be much trouble for you to post a picture.
Thank you!
Mobilman:
My ash pit is a single track with an adjacent ash removal track. It’s a modified Walthers kit with a Walthers conveyor.
This isn’t the best picture of the facility, but it’s about the only one I have. John, the “Newbie” doesn’t seem to get the point that he’s shoveling hot ashes into a wooden gondola.
The ash pit is directly in front of loco #126. This has “stone block” walls. The depth of the pit is the depth of the Homasote, and the bottom of the pit is thus at the plywood layer with some sandpaper down there for texture on the “floor”. A beam supports one of the rails over the pit, while the other rail (closer to the camera) runs along the very edge of the pit. As you can see, one support track in behind serves the sand facility, the coaling tower, and the ash pit. (It is a compact shelf layout.) Two small elevators and hand shoveling lift the ash onto the support track. The ash itself was collected from the ash pile of the Cass Scenic RR in West Virginia, so it is actual ash from shay locomotives.
Bill
Here’s a real one. For ideas.[:)]
Brent
These are 2 Walthers ash conveyors from the servicing area on our Boothbay Railway Village layout. The view is from the ash dumping side; the bucket on the right is being raised to the dumping position. We extended one conveyor base so it will service the further of the 2 tracks in the background. We still need to add scenery to this area.
Why sure! This is a kit I built about 25 years ago. It is still made, but off the top of my head I’m not sure by who.
73
This is the ash pit at Snoggert’s Gap on my SOL RR.
http://i1014.photobucket.com/albums/af269/looseclu/The%20SOL%20RR/AshPit.jpg
http://www.discounttrainsonline.com/Durango-Press-Trackside-Accessories-Ash-Pit/item254-40.html
Folks, thank you for sharing some beautiful modeling examples! You guys set the bar up pretty high - which of course is a good thing.
I was particularly interested in G. Paine’s pictures of the Cornerstone facility as I have the kit. My thought is I could kitbash one kit so as to extend underground to cover two loco tracks. In G.Paine’s example, two kits were used - one for the near and one for the far track.
Thank you all again!
Hello I am a little late but here is mine its only for one track .
Hope this helps Frank
Hello,
I have a photo of the ashpit on my (since dismantled) Idaho & Palouse layout on my blog at allaboard09.blogspot.com
When you get to the blog, please go to the June 2009 entry, and the ashpit is in th first photo.
Chuck
