Hi I have just started modeling this railway in G scale and have several Coaches 4 with Lake Spirit on them! can anyone tell me where I can get other “Lake” names and their numbers to replace them on the other 3? any tips on name and number removal would also be appriciated. Cheers
Lightly rub each name plate with denatured alcohol and look up WP&Y on BING you should find the info you need.
Dave
Thanks but Bing has not turned up the answer. I find water slide decals for WP&YR but now out of stock and discontinued. at a dead end so far ;-{
Hi I have all the coach names and numbers so just let me know what you require[:)] I use WWW.GScaleGraphics.net Ive always found them very helpful when getting coach names and numbers for my W.P & Y.R . Hope this helps
Fantastic! Thanks I knew there must be someone out there who made these. I require names and numbers for 3 cars so far, so I guess I will need 4 numbers and 2 names per coach. I would like If possible in the yellow:-
216 LAKE BLACK
276 LAKE BIG SALMON
278 LAKE FAIRWEATHER
This would be great, do you supply or should I go to GScaleGraphics? thanks again[:D]
Hi go to the company im a private railroader in the UK and I get my signs from the company I put in post[:)]
Hi Ive checked my list of rolling stock Lake Big Salmon coach num is 352 Not 276 Lake Fairweathert coach num 356 Not 278
Thanks for your help, I have the WP&YR book “A Pictorial History” by Stan Cohen and that was printed first in 1980. revised in 1990 and i have the latest 2005 edition. It is an excellent book if you have not read it, and it lists all the WP&YR locos coaches wagons cars flat cars tank cars etc by number, weight length wheel size and these are the numbers that are listed. however, I have a picture I took with me on Big Salmon and it does have a 3** number? I think the passenger coaches have undergone a renumbering in recent times as many new have been added and not all Lake names. So I will have to do a bit more reseach and may even send the company in Alaska an email to ask for clarification if I can’t sort it out on the net. I live in Western Australia now but am originally from UK spent 35 years in Torquay, Devon. that might help you with my user name! I have quite a few pictures I took whilst in Skagway if you might need anything. Thanks again Grant.
This link will explain the numbers, it seems there is a first coach and then a second with the same name but different numbers, so we were both right! Cheers Grant.
opps forgot the link!http://en.wikipedia.org/wiki/List_of_White_Pass_and_Yukon_Route_locomotives_and_cars
