I’m closing in on finishing up my trackplan for my years in waiting basement empire. While fine tuning thngs and adding some of the flavor I want, I’ve run into something I’ve never really dealt with before. First, the background:
Nominally, the mainline is two tracks, with the exception of the hidden track that feeds into one of the staging yards. Originally, I had a curved turnout in the tunnel. Both mainlines feed into the same track going into the yard ladder. There are several reasons I did this, and it is compatible with my planned operational cadence (no train will ever be trying to enter the staging yard at the same time one is leaving). Access was not an issue, as it was only a few inches from the front edge of the layout and readily accessible when I made a test section of the layout. Easier to reach than, say, the headlight bulbs in my car. I did get a little edgy about having more hidden turnouts than I’d absolutely need.
Moving the turnout into the open got me thinking. Given that the track is going into a tunnel, I thought what if the tunnel was single tracked. The layout backstory has some engineering concern why they couldn’t notch the tunnel or drop the floor to accomodate double stacked containers. I know that there are places that Conrail did this sort of thing (which is fitting, because my layout is NS territory that’s ex-CR and exx-PRR). So, you’ve got a two track mainline pinching down to one, but centered on the common centerline of the two tracks as to fit down the center of the tunnel. The real trains call those equilateral turnouts, turns out. No pun intended.
As I went looking for wye turnouts, I noticed that most pre-made wye turnouts are the lone offering in their catalog or have fairly low numbers like a #3. I suspect that this is more like a #6 turnout, because you have two different angles working against each other in the frog number. From my sketching, it is my understandin
