Is it a bad idea to have main lines run through wye turnouts and or the diverging track of standard turnouts?
Sometimes you see it, but in the real world it means both routes have to slow down, but a turnout lets a train run full speed on the main
I have main lines running through the diverging paths of turnouts, and seldom have issues. Of course, I run a model railroad, not a real one, and I am faced with spatial limits that real railroads would avoid.
I don’t run my trains very fast, either, and I’m fussy about my trackwork.
Hi corsiar,
Unless you have unlimited space (and funds) modelling requires compromises. Do what you have to do to get the track plan that you want!
Having said that, sometimes sober second thought will reveal better alternatives. Play around with your track plan. Just don’t do it forever. At some point you have to start laying track.
Dave
Here are some things to consider: your rolling stock, speed, and turnout length. I run a lot of steam, with short turnouts, so I avoided wyes and turnouts for the main to minimize derailments and interuptions. I also avoided magnetic uncouplers for unwanted uncoupling (i used electromagnetic ones).
Simon
NYCT has many places where the main line takes what would otherwise appear to be the diverging route.
Take South Ferry for example. The Mane Lion used to run on the straight leg of the turnout into the old South Ferry Station.
NOW they built the new South Ferry Station and access to it is on what would appear to be a diverging route. Of course subway trains headding into the terminal are not moving very quickly so speed is not an issue.
What is at issue is the HOME SIGNAL. Green over Green is the expected main-line route, in this case the diverging route when looking at the switch poiunts, where as green over yellow indicated the route into the old station which would have been on the straight leg of the turnout.
Between Jay Street and Bergen Street, the Green over Green indication would send a train to the lower level of the Bergen Street station and on to the express tracks.
But the express tracks are no longer used, the (F) train must take Yellow over Yellow to access the ramp up to the upper level of the Bergen Street Station. Even though all trains take the ramp going up, it still remains the diverging route and not the main routing of this signal.
Yor timetable will tell you what is expected at each location.
On the Route of the Broadway LION, the number one track receives a Green over Yellow signal as it moves across the crossover to the number two track for its trip south.
On the NYCT the same Home Signal indicates Green over Green for the same movement.
Either way the train is moving across the diverging points of the switch.
ROAR
I have an Atlas #6 with the divergent being the main. Have run 4-8-4’s and 2-10-2s over it for 13 years, not one problem.
Here is a “Y” switch on the main line of the IRT.
Green over Green moves the train to the left placing it on the express track.
The Yellow over Yellow moves the train to the right placing it on the local tracks.
ROAR
There’s also the matter of “why.”
I mean, up in Point of Rocks MD, anything coming off/heading to the Metropolitan Sub from/to the Old Main Line must go through one to three divergent tracks. Just the nature of a junction.
I have a wye on my mainline and haven’t had any problems since the track was laid in 1990. All my mainline turnouts are minimum Atlas Custom Line #6.
Mel
My Model Railroad
Bakersfield, California
Trying to duplicate this used on Sherman hill before the west side of the tunnel. Top track is main line 1. Middle track is main line 2. Bottom track is the diverging track. On my layout I am using the bottom track as a siding/access to the yard.
I will be running 6 axle diesels, 4-8-4 (844), and a big boy (4014) through.
Yes, I can see how that can work. I have quite a few Peco no. 4s on my layout, due to space limitations. The large steam will take them, but at low speeds only, including a brass Mikado. But based on experience from my previous layout, no. 4s will cause periodical derailments on high speeds with steam when taking the turn. Too often to my taste anyway.
Simon
I would be using PECO code 55 #8 with their wye which they claim is a 24" radius and the #8 is a 36" radius.
PECO N scale Code 55 turnouts are referred to by the manufacturer as Small, Medium, and Large because all have the same frog, about a #6. The difference is in the diverging curve: 12", 18", and 36" respectively. The C55 wye is also a #6 frog and about a 24" diverging radius.
There’s no such thing as a PECO C55 “#8” or “#4”
RULE OF FUMB
Speed = 2x the number of the turn-out
Ergo a #4 turnout is limited to 8 mph.
#6 to 12 mph
#8 to 16 mph
#10 to 20 mph, which is standard for yards on a 1:1
#20 to 40 mph, which is a very fast switch. Faster than that and you will need moving frog points as well. as switch points.
As it is on the 1:1 so it is on the 1:87
ROAR
If you talk to guys who work in 1:1 they will say they hate it when mains take the diverging route, because they have to slow down to avoid derailments. For that reason the real railroads don’t often put the main through a diverging track.
I hae riden extensively on a 1:8 scale railroad were the main often goes through a diverging route and people don’t slow down, and they don’t have any issues from it. Based on that I would think the effects would be even more negligible on a 1:87 (or 1:160, etc) layout.
So the answer to the OPs question is if the OP want’s to be super prototypical, installing wyes or routing mains through diverging routes may not be the best choice, but if the OP doesn’t mind a minor inaccuracy (accually I’d say it’s more of a compression) they will be able to fit much more sidings on their layout.
As a final side note, if you do put the main through a diverging route, requiring operators to slow down through such switches would certainly add some interest (and time) to operations!
Model trains look great running through curves, so I use WYE turnouts anywhere I can, just because trains look better when they go through them.
-Kevin
