yard layout
Well, I am trying on this new website and am a little confused but here goes.
I am trying to compress my yard as much as possible. Here is the scheme I have started with #6 turnouts. The only thing I have not managed is to shorten the turnouts AMAP to get more length in the yard. Does anyone have an idea what more can be done> This seems very elongated for what I want, but… maybe I am just a dreamer! [8)][?]
Jake,
First of all, you didn’t include the following important information:
  • Scale?
  • Dimension of area?
  • Radius of curves?
  • Centerline spacing of yard tracks?
I don’t know what an AMAP is, but if it’s some sort of ‘texting code’, remember you’re not talking on a cell phone here. Looking at your diagram, I’m going to say there is no way you can have your yard tracks that close together. What program did you use to draw your track diagram?
Help us to help you…
Don Z.
Don Z - boy, did I screw up! [:slight_smile:] Thanks for setting me straight!
This is an HO track written with Atlas RTS8.0 program. I have used #6 switches but will actually be building the layout with hand-made #5s. The total length I have is 160" and the width is 19". By AMAP, I meant > As Much As Possible > sorry for making that up! [#oops]
I have laid some track to see how this goes and am overlapping the turnouts to get as close to point-to-point as possible but I am not sure that is the greatest idea either? [sigh] I have one Trainmaster 6-axle that has to at least make the passing track.
Hope that helps. I will also try to go back to the original plan and see if I can add text. Stay tuned please!! [B)]
The length looks normal to me. Ladder tracks in yards take up alot of length. When you add a curve on the end, over half of your total yard space is usually gone.
OK, here is the layout with text added but it seems pretty busy to me. I guess you are correct El Capitan, yards just do take a lot of length. Hope it is worth it! [sigh]
You would be well advised to use 2" separation between adjacent track centres, and 2.5" would be better for handling cars with your mitts if you must. Think of rerailing them, for example.
Handlaid #5 turnouts should work nicely for you.
Your diagramme seems unfinished at the south end of the yard. You only have what must be an A/D track completion with a turnout…are the others all butt ends?
How does this yard fit in a grander scheme? Will it just be the yard and what you show curving until it must dead end at the north end? You may be better off curving the ladder’s rungs a bit…something like a radius of 120-140", with the apex near the operator.
This is how I laid out my yard. It is on a 18" wide hollow-core door.
The first two switches in the ladder are no. 6, and the rest are no. 4 (actually 4.5). Helps with the S-curve into the number 2 track. I didn’t modify the switches in any manner. The number 1 track holds 8 40 foot cars, I think. The runaround hold 5-6 cars. Also room for a small engine house, where the orange building is.
Selector - thanks for taking the time to answer! Yes, I am looking at at least 2" centers in the yard. It is unfinished at the lower end as I hope some day to add another cantilevered 4x4’ table and make a wye at least for turning around.
The whole layout fits together at the top to a cantilevered 4x8’ table. Here is a pic of my garage, which still allows me to park my GMC Sierra (as per the wife’s directions!). [sigh]
And here is the configuration that I have started for that table. You may remember that you suggested I cut down in 2" foam to achieve an underpass instead of having a 3% grade. And I am thinking of a curved turnout on the lower end to give me more table to work with. A work in progress! [swg]
As to curving the ladder rungs, do you mean by using short spacers of 22 or 24" radius? I am having a hard time visualizing what you meant? [%-)] Thanks again.
You should have a nice layout once it is done…nice work so far!!!
I mean, about curving the ladders, that instead of all thos turnouts leading to parallel tracks that are straight, you’ll get somewhat more room in your yard if you curve them, belly to the right as we view the diagramme, with a radius that allows you to have a mirrored sweeping curve at the south end, but also gives you that much more room on each of the “rungs” the parallel curved tracks in your yard. Too sharp and coupling will be a problem, but sharp enough and you may find room for another car or two, or a better configuration of turnouts at the south and north ends. It is still ideas time, nothing cast in concrete, and I hope others chip in with some help. But you are so far taking up tons of room with those turnouts. I’d almost suggest going with #4.5 commercial flip turnouts, say Atlas, and getting more usable length in your rung tracks. Seems a shame to have such short ones at the right side of your yard as you have it laid out.
Jake,
I took the liberty of laying out your track plan with XtrkCad and have attached it here for you. The yard tracks are on 2" centerlines without modifying the Atlas turnouts. I also added a parallel ladder with more storage tracks just to give you more to chew on…
Don Z.
Hi Jake, I’m surprised that no one has suggested laying out your yard ladders with the no. 6 turnouts on the angle of a no. 5 or even a no. 4. This is a space-saving measure that prototype railroads often use, and it lets you combine the advantages of longer turnouts with the compactness of the larger angle. All it takes to accomplish this is a little bit of curvature from the diverging leg of the turnout leading into the yard track. I show this on page 31 of my book, “The Model Railroader’s Guide to Freight Yards,” and also in the example yard on pages 34-37. The photo on page 28 shows a prototype example of a yard ladder laid out this way. Good luck with your layout, Andy
You have 1 main 1 AD and 4 yard storage tracks correct?
Trust Andy. :smiley: I do (and I own that very book he mentions.) It’s good reading.
Here’s my contribution:
Features:
  • Only 1 S Curve!
  • R24 minimum
  • #6 turnouts with #5 angle.
  • 1 1/2’ x 13’ size
  • Engine House
  • Caboose Track (or runaround track)
  • 24" Drill Track
  • Up to 9’ train w/o fouling the main
  • 3 yard tracks (1 inbound 1 outbound, 1 in/out temp.) Total yard trackage: ~23 feet
  • No need for compound ladders (more protypically accurate)
Good job! It would allow for more flexibility, especially leading-in engines, to escape if the purple track diverged south-east a bit above where you show it ending, and ran diagonally, through double slips, to the AD track again.
Here’s my yard ladder:
I angled the ladder to get longer tracks and used compound ladder to fit more tracks in.
Nick
Try flipping the turnouts on the south side of the photo around. So both ladders are parallel to eachother, and your yard tracks are a consistent length. A compound or split ladder would also help.
Don Z - thanks so much! I am astounded how much better that looks with the XTrkCad… and so much more track than I had! I have that program as a demo but have not had the time/courage to attack it. Looks like I should have! [tup]
Mike - I especially like the filled gondolas! You have the right idea… as well as a good yard design! [swg]
Don - yes, that seems to be what will fit on my shelf. Does it look like it will work?
