Yard scenicing
I have a modest yard on my layout and am now in the process of beginning to scenic it. I have combed the internet for pictures of yards and it strikes me that, for the most part, they are rather stark, with either cinders or some sort of ballast between the tracks and nothing else. It also appears that the track ballast is not has “groomed” as it may be on a mainline. Am I off base with these observations?
There are various things you can add: cut up paper to represent news paper etc on the ground (I used plain computer paper, type on it in small fonts, use a marker to color it in various shades to represent photos then cut in small strips and squares depending on scale). Scatter around the yard. Again using computer paper color it rust, brown or black, cut in small strips to represent banding material. Use gloss medium and paint in various locations to represent wet spots or locations. Use Crayola (light brown, yellows etc) powder paint and dab in various locations to represent earth, fallen material from box, grain cars etc. I also dab black down the middle of my main line to represent various locomotive stains. After dabbing it on I will spray with wet water (water with rubbing alcohol added) and this will “fix it” to the ballast. Around switch machines I will use black Crayolato represent oil.
You can also used woodland fine scenic material in earth, grass etc to represented patches in you yard.
I will also cut up plastic building material in very small pieces to represent broken glass. Scatter these around or place in a pile. Remember the safety of your yard working crew so keep the clutter down. Also remember not to over do it.
Any material I add is fixed with wet water and then soaked with white glue and water mix.
No.
Google Maps earth view is also a good source.
Not at all. Most yards are pretty bland, with mostly level surfaces and not much in the way or weeds or junk. This helps to minimise tripping accidents, especially at night, even if the yard is well-lit. There’s probably drainage, too, but rather than a ditch alongside the track, as might be seen on the main line, it’s underground. You may see catchbasin covers or manhole lids, but a yard is dangerous enough without adding obstacles for the guys on the ground.
That’s one of the reasons I don’t model an on-layout yard. My staging yards aren’t even ballasted (although I could probably operate them as sorting yards).
Yards often have a much finer ballast then mainlines as people are expected to walk there. Some, it is close to dirt in an area where I would expect was well drained. In and area of poor drainage a courser material would be used.
Weeds would grow along the edges where there is little or no foot traffic. A track used primarily for storage (MOW cars) could have grass growing between the rails. Such things as spills (coal, oil, seeds, wood chips) from loads make good additions to yard scenery.
Have fun,
Richard
You are on the right track, bearman. This is how i scenicked my yard.
Sounds like I am on the right track (pun not intended). And, I have checked with Goggle earth regarding a yard that is located a 10 minute drive down the street, here in Phoenix. It is a BNSF yard and the local office of the Musket Corp is located there and when I checked it out it looked like that whole yard was ballasted in both white and black material. It also looked like a lot of the ties were submerged beneath the ballast.
Hi!
I’ve been “walking tracks” since the 1950s (CNW - Chicago) and subsequently spent a good amount of time in yards (work related) in Illinois, Kentucky, and Texas. The usual in my experience is well worn and dirty gravel, with weeds and often various pieces of debris here and there. Some in the south use ground up oyster shells (as opposed to rock), and of course some yards are “prettier” than others. Depending on your era and the pocketbook of your RR, I would use that to guide how much “neat and tidy” you put into your yard effort.
Oh, I’m talking about ground cover - and not the tracks themselves, although then tend to be pretty worn and smaller than the mains.
After checking more pictures on the web and here, and reading the advice here, I think I know what I am going to do. Thanks for your tips.
A little bit of debris here or there might add a little interest but I would be careful about overdoing it. Junk is not allowed to pile up in a yard because it could pose a hazard to the workers walking the yard. Same with weeds. Less is better. Make your yard bland. It will be more realistic.
I have decided on a rather bland yard.
Bear:
I think you have made the right decision. Too much junk turns me off. I recall seeing a turntable with a skid tossed into it. I can’t imagine how a wooden skid could find its way into the middle of a turntable pit. No offense meant to the modeller but it just didn’t seem realistic to me. I do like the idea of a wind blown newspaper or two and some weeds around the edges, but not a whole bunch of them.
Dave
How about lighting, sanding tower, fuel. Not scenery but adds interest.
My yard is rather modest, right now there is a turntable, office, warehouse and tower. Eventually, I might try to shoehorn some diesel fuel tanks into the area.
An overpass for cars can break up the scene also.
Steve
I think Grampy’s are perfect. Great work!
One thing, seen in Grampy’s photo but not mentioned otherwise:
The yard tracks are laid with regular-size ballast. The space between is filled with finer material, level with the tie tops. This is then fouled with blown-in dirt and spilled lading, and the results thereof (small patch of wheat where a covered hopper door leaked…)
Anything that might pose a tripping hazard will be removed as soon as detected. Broken glass and lengths of banding material would be quick to disappear in an active yard. Likewise, major lading spills would be cleaned up, or at least leveled to the general surface level.
A run-down, virtually unused yard might look like a disaster area - rails submerging in mud, weeds and brush growing between the tracks (and even between the rails,) lots of blown-in and thrown-in trash. Such a yard would be scenery, not an operating asset. (Track embargoed by nailing an X of scrap wood to the switch target! Saw that at a PC facility in 1975.)
Bottom line. Active yards are rather sparse and clean. Junk and greenery are a sign of poverty and disuse.
Chuck,If you look closely in some major yards you will find weeds along the edge of the yard and may see corn growing in the gauge.Look closely and a air hose or brake shoe may be found.
Yards are not spotless nor are they cluttered with tripping hazards.
That’s one reason you face the direction of travel when riding on the side of a car plus,back in the day you never swung off a car before a switch stand always,but,always ride beyond the switch stand before dismounting.
I looked at several yards in my area using Google Maps. All appear very clean and well maintained. Thus, I would have to agree that the spartan look is correct.
Can you visit those yards from a public viewing area? You will be surprise.
