I am building the next yard siding to increase the total to 2. I laid out the new switch and track to see how much I will need, how long I can build the sidings and and how many cars I can park on each siding.
I started out with the sidings parallel to the mainline but discovered it will not give me enough length on which to park the amount of cars I have.
It has been changed to go at an angle to maximize the length of the sidings to allow me to park 4 to 5 cars on each siding and still allow room for the yard locomotive to couple to the cars to pull them out and park them in the yard.
Note one of the cars is just the body, that is because it is having some repair work done on the frame. At least one more siding will be needed to park the 2 remaining cars plus additional cars in the yard. After the third siding is added I should have room for 2 possibly 3 more.
I have one immediate observation and suggestion: GET RID OF THE “S” TURNS!! You will get additional car space and remove an obvious opportunity for derailments by putting a 6" section of straight track off the diverging rails at the mainline switch (A), then placing a LEFT-HAND turnout (B) to enter the first parallel yard track and continue the yard lead for additional Left-hand switches (C & D), with a 3 - 6" between each turnout, for track spaciing (assuming HO scale). The 6" straight off the main will almost assure that no normal cars will be subject to the “S” turn derailing during backing movements into the yard… Also, do you see the additional capacity generated by this alteration.?? Best wishes for sucessful MRing. JWH
Are you saying at the first turnout, the one connected to the mainline, remove the first connected curve section and replace it with a straight piece of 6". And to that connect the second turnout, but a left hand switch, not a right? And to the second switch is the 2 long straight sections of sidings?
The reason for the long lead into the yard sidings is I will be operating the yard loco at the same time I am running the mainline loco and I want to avoid fouling the switch connected to the mainline. If I can accomplish this with straight sections I will.
I just redid the mock up. Coming off of the first switch, the connected to the main is a short 1/3rd curve, then a straight section of 6", then the second switch. This long lead is so I can pull the yard loco off of the second switch, but stay off of the main while the mainline train is running at the same time.
This does not gain me any additional length on the first siding, I still have room for only 4 cars and the loco. What it does do is move the sidings closer to the main, which probably gains me more room to add more yard sidings if needed and I can see how not having the “S” curve at the yard entrance will potentially prevent derailment.
But why a left hand vs. a right hand switches, switch B, C, D, etc., after entering the yard? Right now I do have one left hand switch on the other side being used as the entrance to a parking spur. Someone mentioned changing it to a right hand to gain more room. I could swap them out and right now is the time to do so before I start purchasing more switches that I will not use or will not need.
So again, why left hand switches vs. right after coming off of the right hand switch into the yard?
Why not park the engine on one of the yard tracks? Then you could make both 9" longer by getting rid of that two short pieces of curved track. When switching without fouling the main is involved, not just parking, you do not need space for just an engine between the yardtracks and the main. Every switching move made is by an engine and a couple of cars, so you’ll need space for lets say en engine and two cars, about 3x7=21"; almost 2 feet. probably even a bit more to get enough clearance
On a small layout like yours the mainline manifest will be back that soon, no switching at all is possible when you don’t have a long enough yardlead. Already in a previous thread by you this was explained thoroughly by a couple of posters.
SUX, I think what RetGM had in mind was to connect a 6" piece of straight track to the divergent track of the RH turnout coming off the main line, then a LH turnout connected to the other end of that 6" piece of straight track. From there, he did intend to suggest adding one or more additional LH turnouts to form a ladder of yard tracks running parallel to the main line.
But, I tend to agree with you that it may not really add that much more additional space to park cars.
If I recall correctly from your prior thread on Help Free a Trapped Locomotive, you plan to back the cars into the yard in order to free the yard loco to escape. That would explain your concern for not fouling the main line with the yard loco.
A thought that comes to mind is whether it would be feasible to start the entry into the yard from the bottom of the main line as opposed to the lower left side of the main line. If a RH turnout could be used in place of the single section of straight track at the bottom of the main line, the “yard lead” would then curve up the lower left side paralllel to the main line and then the yard ladder would begin with a RH turnout with a series of LH turnouts forming the yard ladder. That configuration would give you the needed space to store more cars.
If that idea is not feasible because of the lack of space to curve that yard lead inside the main line, then a more radical approach might be to widen your layout by one foot so that there would be space to curve that yard lead.
Follow Paulus’ suggestion. If you don’t have the extra turnout, put a 9" straight piece there where the turnout would go for the lead and engine service turnout, you can swap it out later. In the meantime this gives you some space to park the loco before it fouls the main, and also gets rid of the S curve, which WILL cause you headaches.
SUX, you are correct in the interpretation of my original reply. The reason for the right /left turnouts is to keep the yard tracks “in reach” along side your main. You do not need the 1/3 18 " radius curved track abutting the switch: it is intended to complete the 30 degree arc of a regular 18"radius curved section, so as to make an easy 180 degree turn for a passing siding at one end of your oval. You could use all right hand turnouts, but that would place the yard tracks far end sorta out of reach. Plus, having the yard parallel to the main will allow you to connect the first yard track back to the main at the far end, giving you a run-around track to get your engine(s) on the right side of a west-bound train in order to yard it without trapping the loco. (You can use two of the 10 degree curved sections and an additional 1 &1/2 " of straight track to form the last yard track beyond your last yard turnout.) Noting Rich’s reply: you could install a left hand turnout “backwards” to give you a switching lead inside your main. this would be in lieu of the 6" straight piece next to the switch off the main. It’s amazing what sleeping on a problem will do! Best wishes…JWH
keep in mind i am combining Bachmann ez track with atlas snap track and remote snap switch. i have to have enough clearance for the switch machine and to clear the plastic rail bed of the Bachmann track. the only rail bed i can cut and trim is the cork. it also has to look right. that is why i used the s curve, for clearance. if there is enough clearance with a 6" straight i will change to that. but i already know i cannot connect a straight to the switch connected to the main and have enough clearance for the switch machine. i have to use at least a 1/3rd 18" radius to push the straight section over far enough to allow the switch machine to fit between its respective switch and the mainline.
train modeler, i will eventually have a larger more permanent layout. the rest of the basement is used for secondary storage. some of which cannot be modified. at one end there was a bathroom with a shower stall. the shower will be relaced. right now this is all i have to work with.
Just a few more comments after your 26 JAN FEEDBACK: The advantage of a left turnout “yard ladder” is that all of your yard Atlas switch machines will be outside the yard, not in the way as is your posted pictures. Also, as others have suggested, you can park the loco(s) on the third track, straight off the 2nd switch, or even use that as a lead to your engine house. After looking at your blog, I used Atlas RTS to lay out the proposals, including an inside reverse left-hand turnout to provide a switching lead, and reconnecting the first siding to the main for a run-around/arrival track, and it all fits!! Looking at your Blog, I notice the passing siding/run-around with an escape turnout . That turnout, as you suggested could be used for the first yard throat, and be replaced with the right-hand turnout, so as to have a straight exit from the siding, eliminating the “S” curve, and providing an acceptable curve leading back to the main. With the purchase of only one or two additional L/H turnouts, you shouls have a smoothly operating layout. Again, best wishes for happy MRing…JWH (yeah, most of my experience has been on 12" to the foot scale)
I am confused as to why anyone is offering to help when I did not ask any questions. I was just trying to merely show what I have done so far, not ask for help.
I have made changes that will be indicated in my next reply. Thanks for the advice but I know how I am going to build this layout. Please don’t offer help unless I ask a question.
From what you’re describing with using LH turnouts instead of RH, it would put the yard sidings truly parallel to the mine line and with one another. Doing this shortens the length of the sidings. I need to be able to fit a minimum of 4 cars and the loco. on a siding where the front of the loco. is not parked on the turnout. Putting the sidings parallel to the mainline will make the sidings too short.
Therefore I have built this, with two sidings for now:
Please note the reason for the long lead into the yard. This will allow me to switch the yard locomotive to the different sidings at the same time the mainline train is running. This is how this part of the l
SUX: You are confused that people are trying to help you?
You have asked a lot of questions and a lot of people have responded with what they hoped would be helpful answers, including me.
None of us are trying to force you to do anything that you don’t want to do. All of us are trying to help you. Your paranoia is absolutely unjustified, and I think if you don’t retract that statement you find that very few of us, if any, will be willing to follow your layout progress in the future.
We are engaged in a dialog here. By posting something it is assumed that you would appreciate feedback. If you don’t want any more feedback then please say so clearly and we will leave you alone! I think you may already have done that but I am hoping that you don’t really want to cut us all off. Your layout has a lot of potential and you have clearly given it a lot of thought. I think most of us would like to stay involved.
We are talking with you, not dictating to you. Personally I was enjoying the conversation, and the progress in your layout.
I can say little more other than to echo hon30critter’s comments.
You say you are offended, but as someone who has commented on your threads and offered advice, some of which you have followed, I am astounded at your statements.
If you just want to post photos and make comments about your work, fine.
But, in turn, I would urge others not to comment at all. Make it a thread so one sided that it only contains your posts, nothing else. And I say that, respectfully, because that is obviously what you want.
But where does that leave you?
You know, from your own comments, that your track work could be improved. Others have merely commented on how it could be done in response to your implied call for help and advice.
I agree with hon20critter that a retraction of those comments is in order. Otherwise, why should we even bother to look at your threads and your photos?
dexter nice pun considering SUX is the airport designation letters in the city i live. going forward if i need help i will all a question or disclose i need help. if not I’ll simply state i am not along for help but general comments are welcome.
