Thanks to everyone for helping me to get my plans ready to build! I have done my benchwork and am starting to build the layout!
**You can click the links prior to each picture for a larger version.
I’d strongly suggest that you stop where you are, hang some drywall and get that room semi finished before you go much further.
The concrete dust from the walls and the grit that will fall from the rafters will be a constant problem if you don’t. You can also take some time and invest in some decent lighting fixtures, too.
Also, please re-size your photos to 800 wide before posting in respect for our dial up brethren. It takes forever to load those giant images!
But otherwise, keep us posted on your progress!
Lee
Can.t agree more on finishing the room. dust and dirt are a killer, and constantly cleaning the track isn.t one of the fun parts of the hobby.
I’m going for real-world feel - prototype is out in the dust and dirt
Seriously though, while I’d like to finish off the room, my budget does not allow for it. I’ve run layouts in the past in similiar conditions without problems.
It is natural weathering
While resizing images smaller may help the download at dial-up speed, those of us with faster links might prefer the largest possible (sharp) image. I think those who link to large images should provide a link to smaller ones for the dial-up crowd (recognized this takes a bit more time, but is far more courteous to other members of the forum.
Just my 2c
Doc
Thanks Doc
I have added links for dial-up users…
Shouldn’t it be the other way around? What’s the point in linking to a smaller image when the larger ones allready have been loaded in this thread (the forum resizes the images -after- they are loaded, unless of course the dial-up user has deactivated image loading in his/her browser)…
I suggest loading small images in the thread, and provide a link to the larger ones for those of us who want to take a better look, that way the dial-up users won’t have to wait forever for the page to load.
Just my [2c]
Svein
Makes sense. Done
Starting my yard - couple more pics. Plywood base just for yard area.
One suggestion…
Next time, consider putting the L-girder such that it is on the other side of the leg with the flange facing out. That way you can adjust and fasten risers joists more easily.
Don’t sweat it to much… your bench work is fine, just something to think about next time you do this.
Chris
In example:
Thanks Chris - yeah it was kind of fun attaching them the way I put them
Thought I said that
I always re-size thumbnails on my web site with links to larger (or very large images). I think it’s not a bother to take the extra time to re-size a photo for posting and add a link to larger (Windows XP PowerToys has a re-size widget to do handle changing image sizes in the Explorer window).
Why the left turnout to the right of the passenger cars, wouldn’t a right turnout be better…?
Svein
Svein
Good question - the siding there was intended to be parallel to the edge of the layout, while the yard is at an angle. That siding is for maintenance, and I wanted it a bit differentiated from the yard. Now that I look at it, it does not really make sense, I can do the same thing with a RH turnout, which would look better…
Thanks for pointing it out. Easy to change now… now I know why I am posting my progress photos here…
Nooooo!!! Not another progress layout with photos!!! heeheehee
Keep 'em coming!!
And nice suggestions on tracking btw.
Glued down my yard underlay tonight!
I think I’ll put up a blog with progress photos soon. Got my backdrop screwed on all around this weekend - looking nice. Realized that one section of my layout will need to be removable in order to get proper access to furnace, water softener and water shutoff. I will need to make some minor adjustments to the benchwork and attach that section with bolts and nuts, and make sure the scenery is split at the seam to make it easy to disconnect when needed. Glad I realized it now and not later…any suggestions on tips for removable sections - please let me know.
Will post pics and blog link in signature later today or tomorrow.
ETA: Blog is up with pics!!! Check link in my signature…
A bit of a delay as I figured out how to separate the movable section, yet keep it firmly attached. It now has three places with bolts and butterfly nuts that match it to the fixed section. Needed to move the bottom backdrop screw up so it will be accessible later. Hope to get the backdrop painted in the next couple of days.
