Deciding to model the nearly same time and place as Spacemouse, I quickly arrived at the same “slim pickingsin period locos” conclusion as he did, and prioceeded along a slightly different path.
The MDC 2-6-0 and 2-8-0 kits I have will take a while to complete, and will probably need to be re-geared and possibly re-powered before they see service on my road. The Model Power 2-8-0’s I have are tender driven, and since it offers low weight, valve gear resistance, and since the tender’s pushing it, has problems staying on the track. Some of that may have been alleviated during the last major track tweak, but I won’t know until I get the remainder of 25 years oxidation off all the brass cunductive parts.
On the other hand, the Spectrum 4-6-0 has the same boiler diameter as all my other 2-8-0’s (in the front anyway, it unprototypically swells towards the back) is only two feet longer than the 2-8-0’s, has a “legal” wheel arrangement for the road and the period, and the worst offenders appearance-wise, the stack, pilot, and headlamp are all easily replaced.
The MDC kits all have 4 stacks each, the headlamps are in the pipe from Durango Press, and the pilotsare probably available from precision Scale, if I can just get to the local rep’s place while they’re open, to pick up a catalog.
But the real deciding factor for me was how the Spectrum runs. It’s light, true, it can only pull three MDC Overton shorties up a 5% grade, but that’s all the prototype ever managed so that’s all I need it to pull. The 4-6-0 runs as close to silent as any loco in the fleet, diesel and steam, which includes P2k, Genesis, Spectrum, Atlas, and Kato equipment. The only sound you hear is the valve gear, a click here and there, sort of an oiled glass whisper from the slides, (that sound to me like they really…really…LIKE to run) and that’s it.
Two more on order, and if the MDCs and Model Powers aren’t up to snuff, or can’t be brought up to suff, the Spectrum 4-6-0s will be th
