Your Layout
Post pictures of your layout here so people can see it. Or link to a layout page
Sorry, this forum doesn’t allow posting - that is to say it is not set up for it. There are plenty of other places to post your pics, or you can put a link in your message here.
Andrew
My layout you would not want to see!
if i had a layout and i had pictures then i’d probably post a link or something. but until then. i won’t be able to.
This is a link to a photo of my HO layout under construction.
http://www.the-gauge.com/forums/showthread.php?s=&threadid=6370
This is the 10 year old N scale layout that I will be re scenicing.
http://www.the-gauge.com/forums/showthread.php?s=&threadid=6533
Nice stuff Ray, your live steamer project is awe inspiring, very clever. I hope your firing problems have been solved. Two thoughts for heating water, Butane or NiCad, a portable soldering iron could provide the parts.
I recently acquired some neat new software that lets me show pictures so I put a bunch on one of my sites.
http://www.hairyotters.com/gallery/
Just gettin’ started on my first layout, 5’x12’ HO. http://members.cox.net/dbhuff/dsrr/
Thanks Tony,
Working on a Butane fired boiler. (still on the drawing board)
Nice photos of your work. I like the double header with Heislers
Snake,
Lookin good. Your making good progress on the layout and the electronic section on your site is a nice touch.
For shots of my East Central Indiana HO scale layout, you can visit http://cid.railfan.net/eci_new.html
I uploaded some photos of my recently dismantled WP layout in the WP 8th Sub album here:
http://photos.yahoo.com/wp8thsub
The layout was set in terrain reminiscent of California’s Feather River Canyon. Post to advise me if the link doesn’t work and I’ll fix it.
[:0]Sure we would! It couldn’t be any worse than mine! LOL
ray
Nice ho layout
Nne question
Nhat did you use for the texture of your scenery?
looks like a spray of some sort
THANKS
GLENN
Glen,
The texture is the result of the shaping of the foam. I used a hacksaw blade to rough in the shape of the mountains . Then I used a rasp to smooth out and blend it all together. I also carved rocks in some areas with the saw blade. All seams were then filled with drywall joint compound ( smear it on with your finger) . Then when dry everything was smoothed out with 60 grit sandpaper.
I had quite a mess going while I was doing this. Nothing the shop-vac couldn’t handle though.
I plan to put a couple of coats of latex paint to seal it and provide the base color, add some ground foam in certain areas, then airbru***he final colors.
By the way, the 2" foam I use is the beaded type no one seams to like. It works for me. ???
In the process of being built,mine is 9x 11 n scale and features 64 turnouts,a 4 track hidden staging yard.DCC cab control and uses traditional methods of Benchwork and hardshell scenery.It features a heavy iron ore hauler(Dm&IR) that interchanges with 2 class 1’s (NP and GN)and has shared trackage with 1 of them (Great Northern)It will feature a large yard and servicing area.a large city and port,a small ore classification yard and 1 additional small town.it will include several rail served manufacturers and is set in the late 50’s when steam was still running alongside U Boats,sd-7’s and 9’s
Geeps RS units etc. a smaller road (the D&NE) will also show its face on occassion in the form of a bachmann connie(still sporting its DM&IR livery from whence it came) .Atlas came out with a pair of SD-9’s in DM&IR at the perfect time.Merry Christmas to me :slight_smile:
Link is
http://www.michops.org
Look under layouts and Clinch Valley
I could if I would, seriously.
Right now it is in a state of disrepair undergoing a change
for better operations. It is in an ugly stage now. TRASHED !!!
To post a photo at this time would not do me justice, I do have
plans on creating a sight when it does operate correctly and I
feel it is presentable. At the same time, I will be hosting an
open house to celebrate the occasion.
