Z Stuff Controller
I just connected a DZ 1002 controller to an Atlas Switch machine. I operate conventionally and wired the controller and machine as shown by Gargraves. The machine and controller work but both LEDs stay lighted instead of one at a time. Any suggestions?
Bob
You should try to push the liuttle LED light bulbs in a little and see if that helps. Also try throwing the switch manually and se what happens.
By the way, what is a DZ 1002? I have heard of a DZ 1000 & a DZ 1008.
Lee F.
Are you certain wiring is correct and insulator pins are in the proper place?
I checked with Z-Stuff. Apparently their controller LEDs will not operate with the Atlas switch machine. The DZ 1002 is the controller number.
Bob
