I am finishing the control panel in the area around my turntable. The panel will be the subject of a future thread. The panel controls various accessories and fourteen(14) switches that are near the turntable and transfer table.
I decided that I would use the DZ-1002 controllers and install them on the panel itself. They are small and easy to attach. I am also using MTH DCS to duel control the switches.
One thing that you notice using the AIU alone is that the indicator LEDs on the switch machines will NOT stay lit after the switch is thrown UNLESS it is attached to the controller as well as the AIU. So as much as I would like to forgo the panels and unless I am willing to invest in more Z-Stuff stuff, you need a panel . I guess I could locate controllers around the layout near the switch machine, but that would look too busy.
The problem I am having is that there are no internal wiring diagrams for either device from Z-Stuff; the switch machine or the controller. The hook-up wiring shown in the instructions doesn’t explain that in some cases I have had to reverse the position polarity of the LEDs to get them to work.
I’m not referring to the fact that you can remove and reverse the location of the LEDs to match the turnouts, but instead I have needed to reverse the LED themselves by removing them and then turning them 180 degrees and reinserting them. I’m guessing that the LED acting as diodes restricts the direction of the current ( Without a wiring diagram I am just guessing that that is what I am doing) in each device and screws up the operation such that the LEDs either won’t stay lit or pressing the opposing buttons on the controller switch the opposite line direction on the switches.
By reversing the LED the problem is cured.
Alan
