A recent purchase through E-bay has brought me my first ZW transformer to my RR collection. When testing it out for the first time, last night, the right side seems to work properly. Left side has no power at all. From other listings on E-Bay I see many adds for rectifiers that are being used to replace the defective ones on older model of ZW’s. Being my first, that I have owned, I am not familiar with its overall repair problems that can effect the lack of power to the left side of the unit. Any words of wisdom would be greatly appreciated. Are there any manuals posted that may help in my research as to the repair of this item? I have waited a long time to get one of these power units and I want to make it last my lifetime.
ZW transformers do not have rectifiers. They are AC units for Lionel trains. To use them on scale DC trains, though, you do need a rectifier. Their starting voltage, though, is so high that you really need a big (10 ohm, 40±watt) sandbar resistor to use them on scale locos… A better use is as an indestructible base power supply - at 275 (?) watts, you pretty much can’t overload them with anything we run…
The other answers are partially correct. The failure of the left side of the unit has nothing to do with the diodes. The ZW has roller contacts that move across the transformer windings to vary the voltage. This is not working correctly on the one side.
The diodes are used only to blow the whistle or sound the horn.
The folks on the Classic Toy Trains forum on this web site can give you better advice. If you are at all uncomfortable with taking your ZW apart, I strongly recommend you find somebody who can properly restore and repair your ZW to be the fine piece it is supposed to be.
