zeroing out a NCE Cab 06PR
Group I cant find anything in the search. How do you eleminate all recalls stored (engine addresses) from the Cab 06? I was wondering if you had to eleminate each individually or could you wipe them clear all at once. I have an operator that has been playing around with the shift/esc & direction buttons and acquiring other peoples locos. I cant fire him because it is me.
Thanks
Bob D
I’d do it the same way that I do it with the ProCab: select loco, enter zero, then press enter. Recall the next loco and repeat.
I don’t have the CAB06, but for a ProCab Radio throttle,
Press the ‘PROG/ESC’ button 6 times until ‘SET CAB PARAMS’ shows on the display and press ENTER.
At the ‘Number of Recalls’ prompt, enter 0 or how many ever you want, up to 6, and press ENTER.
At the ‘CLEAR RECALLS’ prompt, press 1 for YES.
Press ‘PROG/ESC’ to return to normal operation.
I think it is quicker to just select loco zero however many times is required.
