Okay, I use two ZWs on the layout and today the grandson, four years old, was using the horn switch to blow the horn on a Lionel Dash 8 40C. After a spell of other running I looked at the ZW and smoke was pouring out of it by the whistle switch and the switch was stuck in the on position.
My question is what happened and how or what do I do to fix it.
The rectifier and/or resistor/resistance wire overheated. They are designed for intermittent use only, not continuous duty. It’s hard to say if you weren’t watching what happened first - the stuck switch or the smoke-out.
I have seen this problem. The most likely cause is a broken return spring on your whistle switch. If the switch is held just so, a short is created inside the transformer that is not protected by the internal circuit breaker.
The whistle switch can be repaired. The spring and replacement rivet are available. It will be necessary to drill out the old rivet (drill off the clinch), and clinch the replacement.
IMHO, the transformer needs to be inspected / checked for any other damage that may have occurred.
The ZW that was on my bench with the same problem had no other damage.
One specific test I recommend on all transformers: AC leakage.
I picked up a Simpson 229 AC leakage tester specifically to test transformers.
