any one know of a “one stop” shop fow ZW parts? I have googled it and it brings up alot different vendors but none of them seem to have a complete selection.
I have 6 of them (could reduce it 5 if particular parts are scarce) that I want to completly refurb before bolting them to the layout. the main parts are some outer handles, diodes, one needs new terminals, and rollers for all.
I want to do the stud mount diode conversion. I also need cords, but I can get them at work. (the original Lionel cord isn’t important to me)
Ryan
You should be able to get replacements for the parts that originally were installed by Lionel from any good parts dealer: I recommend :
Chuck Sartor at http://only3rail.com/
http://brasseurelectrictrains.com/
http://www.ttender.com/
and there are still many others.
The diodes represent an upgrade from original equipment and I have not seen them at train parts stores.
http://www.mouser.com/r would probably be a good place to look.or perhaps http://allelectronics.com/ Be sure to get exactly what you need. There are several specs to consider.
Thanks for the info., looks like I’ll be able to get what I need
Ryan
A silicon diode is probably longer-lived than the original copper-oxide rectifier. But the forward drop of a silicon diode is somewhat higher than the copper-oxide and thus worse, albeit slightly, than the original design. If the copper-oxide rectifier is okay I would leave it alone; but, if it has failed, then a silicon transplant is indeed called for.
You can call Davis Lyons in Burlington NC. He sells diode kits. He sells on Ebay too.
Roger
You can try this for ZW parts; www.http://lioneltransformer.com/
