I checked the olsen diagrams but they do not have a detail of the assembly that covers the axels on the right side of the transformer. Mine is apart and I want to be sure to assemble the various parts correctly.
ANyone have a diagram?
Also, there must be a procedure to assemble the inner voltage ring (which is the part I am replacing) and the throttle handle. SInce it is spring loaded I thought I would assemble it placing the holding pin in first and then the inner ring and outer throttle isnulators and contacts and washers in the correct order, olsen has a diagram for that. Then place it in the transformer and assemble the whistle reverse on top of it.
