0perating mth conventional engine thru a wtiu
can i run seperate tracks with an mth wtiu-how do you control seperate tracks with a wtiu?
Welcome! You have asked several questions here–the question of your subject line (operating MTH conventional engine through a WTIU) is not the same as the question in the post (can you run separate tracks with a WTIU).
Can you use a conventional MTH engine with a WTIU? Sure, but depending on what engine you have, you may need a remote if the engine doesn’t have Bluetooth. You’ll also need a cable to tether the remote to the WTIU.
Can you use the WTIU to control separate tracks? Yes. You might wish to read some of the WTIU information on the MTH website: https://mthtrains.com/news/879a#:~:text=The%20WTIU%20will%20continue%20to,layout%20to%20the%20next%20level.
We at CTT have only just received this unit and are still learning about it. We are also expecting a review from Chris Montagna soon about the WTIU. Stay tuned.
