1/148 vs 1/160
Does anyone know if there is a big difference between the two. If I took a 1/148 vehicle and placed it up against a 1/160 vehicle could i tell the difference. I saw a 1/148 hearse on Ebay I liked but all my current cars are 1/160th scale.
The difference is just about 8%, which means that a 63.5" person in 1:148 would scale out to 68" in 1:160. Unless you put identical vehicles, one in each scale, right next to each other, the difference shouldn’t bee that noticeable. Since the vehicle you are looking at is a hearse, which would ordinarily be both odd size and larger than most other vehicles, it shouldn’t be a problem.
I have a similar situation, since I model in 1:80 scale and use HO (1:87 scale) figures and accessories. I can get away with that, since the typical Japanese was physically smaller than the typical European and many of the small items like shovels and jackhammers don’t have a single, standard size.
I was looking at 1\144 and 1\160 scale vehicles…when you get down to that scale there is absolutely NO WAY you can tell the difference! If someone shows up with a caliper and slide rule and starts to measure they might discover one is half a scale foot too large, but not the general population that will be viewing them.
If someone shows up with a caliper and scale rule, I’ll confiscate them! As for a slide rule, I replaced mine with a pocket calculator back in the early 70’s.
Chuck (modeling Central Japan in September, 1964 - in 1:80 scale, but not a fanatic about it)
The difference between 1:144 [probably not :148] and 1:160 will be apparent from across the room immediately. I made the mistake of thinking it wouldn’t and bought a bunch of Racing Champions cars, which are really nicely detailed 1:144 diecast metal. Mixed in with my CMW, Busch, and Wiking vehicles, they stood out like the proverbial sore thumb. They are resting in a storage drawer, out of sight.
ham99 hit the nail on the head. I saw a layout at a Knoxville, TN show some years ago. They used 1/144 vehicles liberally and they were obvious at a glance. Parked next to a building or near figures, the difference was glaring.
The only way they might work would be to put them on a country road away from buildings, people and trains.
You could use them in the foreground to force perspective to the real layout in the background.
