I watched a Turner Classic short involving Robert Ripley. This was a man on a horse waving a flag to warn all of a NYC switch job coming on the tracks. NYC 1400 series (I believe) locomotive. Was this an early Intersol Rand internal combuston locomoitve? Was this filmed in lower Manhattan?
NYC’s tri-power (diesel-battery-third rail) locomotives (prototype by Alco-GE-IR, all the rest by Alco-GE, but with IR engines) were used in lower manhattan to replace shrouded steam locomotives, both rod type and shays. Tri-powers were in the 1500 series. There were spots in Manhattan where they used the streets until well into the 1940s.
Google ‘Death Avenue’ in Manhattan for some of the issues involved with street running on both 10th and 11th Avenues.
These were really third-rail locomotives for the West Side line. Peak speed was about 19mph electric. The battery was used for going into warehouses and other tracks where third rail could not practically be provided; battery speed was at best 9mph but that wasn’t a problem for Death Avenue traffic.
The oil-electric engine only kept the batteries charged; interestingly, you couldn’t float-charge the batteries from third rail.
New York Central wasn’t the only railroad operating in lower Manhattan streets. B&O had a car float bridge and a small yard serving a coupe of warehouses.
That’s why they had diesels charging batteries. I seem to remember that the St Johns Park terminal was south of the ned of the third rail, and usuall switched by battery.
NYC andCRI&P had some versions without third rail capability.
I don’t remember the elevated ‘replacement’ High Line terminal being called anything but St. John’s Park – but I’m not much of a NYC operations fan.
There is exceptionally good photo coverage of the redevelopment project, which would surely involve documentation of the terminal facility.
I find I continue to miss the elevated lower West Side Highway, that used to go all the way around the tip of Lower Manhattan to the East River Drive without lights. I got to drive it exactly once… but in the Thunderbird with the top down. It was just like flying over all those congested cross streets and river traffic… as did the railroad.
You’re both right (sort of). The new terminal was set up to handle traffic on the High Line, after which the one on the surface track was taken out of service. The name moved with the terminal operation.
Yeah, when I said “actual” I meant the one that was built where the actual St Johns Park had been (the square where the Holland Tunnel roundabout is now).
The OP says it was a 1920s movie. The Alco-IR tri-power #1525 was built in 1928. but the GE tri-powers were built in 1930. Also the Second Diesel Spotters Guide has a photo of a 1924 experimental GE/Ingersoll-Rand diesel on the West Side Line with a horse escort. It looks like a boxcab with a rounded front.
Oil-electric is the Liberty Cabbage of locomotive technology – it’s a way to get the Hunnish word ‘Diesel’ out of compression-ignition engines. Solid (including jerk-pump) and compressed-air injection do not matter as long as ignition is from compression heat.
I think you may be remembering ‘distillate engines’ (like the one in the UP M-10000) which burned a ‘safer’ (and cheaper) less volatile fuel but still relied on spark plugs – sometimes 4 per cylinder – to accomplish the ignition.
And then there is this, good enough to have been given a full spread in Trains Magazine:
I don’t think that’s right. The Dan Patch Electric Lines - credited by some sources as the first railroad to use internal combustion / electric locomotives, bought several “oil electric” locomotives c.1910 - long before WW1 even started, let alone US entry. They were basically electric boxcabs modified to have an oil electricity generator and fuel onboard. They weren’t diesels, they didn’t burn diesel fuel.
My father was given a set of the 1928 Encyclopedia Britannica, the ‘second best edition’ after the 1911 one. That was where I first encountered ‘oil-electric’ as a locomotive type (with pointed absence of that ‘D’ word) and they explained where its general use in the Twenties came from.
I have never seen a Dan Patch reference that said the motors were anything but spark ignition with volatile fuel – I’d believe them as ‘hydrocarbon’ burning engines (which was an early big word for petroleum-derived fuel from the late 1890s up to the GE gas-car era). I thought the engine was similar to the V-8s in the contemporary GE railcars. I will go take a look and check.
Like they said, the 1525 appeared circa 1928, and probably none of the enclosed steamers that preceded it were in the 1400s. GE 8835 had a rounded cab front – it demonstrated in 1924. Don’t know of any other possibilities.
What we need is access to the Ripley ‘short’ itself, to see what the locomotive actually is. All other discussion defeats itself.
As the ‘Believe it or Not’ shorts were all filmed between 1930 and 1932, I would be surprised if the actual result is other than one of the Tripowers, but who knows? perhaps they used earlier stock.
I have seen the Dan Patch engines referred to as “gas electrics” so the motors may have been gasoline powered. Either way, they weren’t diesels, and the ‘gas electric’ or ‘oil electric’ terms AFAIK were not coined to obscure the German name Diesel during WW1.
Oddly enough, when the Dan Patch Electric Line - formally, the Minneapolis, St. Paul, Rochester and Dubuque Electric Traction Company(!) - was reorganized after the owner’s death as the Minneapolis Northfield and Southern Ry., they sold these engines off and converted to steam…sort of a reverse of the “transition era” that would come later. They began buying diesel switchers c.1940, and were all diesel by the end of 1950.
Along with the GE gasoline V-8s (e.g. GM-16/4), GE was experimenting with ‘Diesel’ power in the early WWI period, with the original Jay St. Connecting #4 being one result. It was well-established over the years, in many sources, that use of ‘oil-electric’ was a codeword to get rid of German nomenclature; you will note how quickly the world went back to calling them ‘diesel-electrics’ in the Thirties, along with the diesels in construction equipment and trucks.
