Hi, this is my first post, and I would like to start by saying Really appreciate all the great things I have read on this forum prior to this post. That being said, I have a space limitation. I have a 10’x13’ room, with two walls occupied, one with closets, and the other is a required walk way through the room. It is a ‘mud room’ with 2 entry points.
I have decided I can squeeze in about a 5.5’x9’ layout in there, but it has to be cornered. I had initially though 4’x8’, but after reading here and other places, i realized I would not be able to get the type of operation that I had desired.
This is what I am shooting for:
HO Scale
Operation, I would like to have a switching yard and a few industries
Continuous operation…I want to see my trains go
Going to be freestyle, but I want to model the 50’s, 60’s…Diesel.
North Coast Railroad, now defunct, but that is my line, was a lumber orientated railroad.
Industries I am thinking of will be timber related, not a logging RR though.
Ok, I know I have space limitations, but i was thinking of doing a donut layout…similar to the 'Heart of Georgia Rail Road". I can make a 36" square in the middle of my layout, or even a bit bigger. I Can crawl under, no physical limitations…this would give me easy access to every section of the layout, since it needs to be in a corner. I can make the long side the narrow side and still have 24" radius turns on the outside. My initial plan was the Atlas ‘Trunk Line", and I have used there software to c reate a comparable layout on a 5.5x9’ board.
Has anyone ever done a donut on a 5.5’x9’ board? does any one have any other ideas?
If it were me, I’d do it as you describe. I don’ like low radius curves, which for me would be less than 26". I was also granted a corner of our basement. I would have needed curves down to about 24" had I made anything except my central operating pit surrounded by four rectangular modules bolted together.
I could do without the duck-under, to be frank, but it is a small price to pay in order to enjoy being surrounded by a layout with scenery and sweeping curves. With some thinking, you can still have a rudimentary switching and storage yard, and even maybe some temporary shelving to serve as a staging element. And with the space you describe, you can have a small urban setting and some industrial servicing.
Just take your time and work out the details. Think of curves and inner tracks parallel and what that will mean to the inner radius. Frog angles will be important, but I’ll bet you could use #6 turnouts easily, and they will handle virtually any engine you can find, except maybe a 10-coupled expensive brass steamer.
Thanks so much for your reply. I just wanted to see if any one had some input on the feasiblity of my duck under layout. I can have 9 sq ft in the middle, amybe a little more, and still get a 24" outside radius and a smaller yard for swtiching. I also figured out a way to service a few industries. I am having trouble on the inside radius for the parallel track, but I am working on it. I may just start with the oval and build from there. I would like to be able to experiment with scenery, as this is my first layout, and this will give me the ablity to have about 4 unique areas. I really wanted as realistic operation as possible, and that just was not going to happen with a 4x8. and I am just under 6ft x 9ft…I think I can make a pretty darn nice layout, at least a nice 1st layout. Thanks again!
If a liftout section is not possible or too difficult, I would set the layout height as high as possible to make the duck more of a “nod”. Try to mock up a test shelf at varying heights and see how bad the duck is vs reach across the shelf. You could also turn it into a “roll under” by getting one of those stools on casters that doctors seem to have.
I was wondering how much “mud” gets in your mud room, as well as how much family traffic goes in and out. Dirt and accidents (I’m picturing my 7th grader’s book bag) could be detrimental to the layout.
With your 6x9 you can do more than you think while you plot to take over more basement. I started with 4x4 in N gauge and quickly went to 8x8 in Ho and eventually bridged to another 7x10 section. Always looking for ways to expand [:D]. While some don’t like under a certain radius, it all depends on what you plan on running. I run 22 inch min radius and have everything from MP15Dc switchers to GP40’s, SD70Ace’s, AC6000’s and a recent Y6B steamer and run without any problems. It’s your little railroad and you can do what you want with it. I would suggest that you paint the walls a sky blue color as a minimum unless you are putting in a backdrop. The light colors will make the room look larger and make any pictures stand out better.
Thanks for your input, I am 6’3" tall, and I have thought of that. I am young enough where bending in and crawling doesnt hurt yet, but, I am going to need to work in that space as well. So, I was thinking about it being about 4 foot tall, but that is just a speculation right now. I want to make the height good for viewing as well.
Any suggestions on height level? Given that me having to crawl in there is not an issue, but the one who will be enjoying it most is me.
The mud room is pretty mud free actually…even though I live on a 300 cattle ranch in the Pacific Northwest. We have two front doors on our porch, one to the mud room, and the other to the kitchen. It is more of a pantry for us and a place for us to kick off our boots, and then walk in the kitchen. The wife has ‘given’ me that room, so I am comfortable with governing its use. The only thing I am concerned with is the humidity in my area. Also, we are ‘just married’ and no kids as of yet.
The great news is that this evening I completed all 4 sections of my layout bench work. I have 2, 2’x66" pieces, and 1, 1’x3’ piece along with 1 18"x3’ piece. tomorrow I will create some legs.
So, I have 2 questions:
any ideas on a good viewing and operation height? As stated, I am 6’3", and the sole person building it, and the one who gain the most enjoyment.
This is jumping ahead, but I live in a rural area, and I can not find a dealer less then 90 miles away who sell either pink or blue insulation material. Are there any alternatives? should i just plan my lay out off the supports? like cut plywood to a bit larger then track width? like the L girder method?
The higher up you can build your layout, the better it will look while operating it - you get the feeling of being the engineer, especially when your loco is equipped with sound.
I am 6´5" and I have established a height of 60" for my planned layout, for which I will be using the old-fashioned cork roadbed over plywood method, as Styrofoam is too expensive where I live.
For a single level layout run by a single person - a pretty good compromise is about mid-chest/elbow joint height for that person.
I.e. layout track level somewhere around the range of 42" - 52" off the floor for a layout to be operated by a 6 foot tall man.
High enough for not having to stoop too badly to get under the layout, high enough for a mostly side view angle into scenes (rather than the helicopter pilot view), low enough for good reach far into the layout.
Also remember that the bottom of your layout typically will be 3-4" lower than the track level, and that’s the level your head will have to go under while ducking under things.
I think i will be going with 48" legs…THat should be high enough up off the ground, and I still have a bunch 8’ pieces of 1"x4" laying around…so it makes some economic sense as well.
I was hoping to make the layout on the light weight side, and I though the insulation board we be a good option. Closest dealer is 90 miles away…not even sure on the price either…
Anyway…it is going to be tough to work knowing my future model is sitting on the floor of my mud room wiating for me to add on some legs!
I am 6 ft tall and my layout stands on 48 inch legs. I wish it was a few inches taller, only because I get too much of a “bird’s eye view” of the layout, rather than a more horizontal view. You want it low enough to be able to reach to the back of your modules, but high enough to give you a more realistic view of things. If you want the wife or guests to have a good view, maybe that s/b a consideration as well.
You also mentioned you wanted to experiment with scenery. It would be easier to create below the track scenery if one of the modules was sitting on legs that were 6 inches shorter than the others. You could use risers on that module to keep the track level while having the ability to try some scenery below the track.
My wife is 5’1", so, if I make it 50", she will have no problem taking pictures from a great vantage point!
I do want to ‘experiment’ with scenery types and methods, being this is my first layout, I think around mid chest level would be great, and I plan on raising all track above deck level so i can make it as realistic as possible. I am just having a hard time thinking 2 inches will play that much of a difference, given the money I will save on materials.
Later, if it is not high enough, I can add to the legs, or just construct new legs.
Thank you all for your opinions and advice. I look forward to implementaion. I Hope to post some photos of my bench work if not this evening, then tomorrow. [:)]
Ok, I understand what you are saying. I will try it out before I cut any more wood. I would like to have a comfortable level to work at too. I figured chest height would be good for that…It will be over 48", I will tell you what I decided on and post photos of my results. Thanks for your input.
I’m big on experimenting with these kind of theoretical ideas. Before you cut those 2x2s, just clamp the benchwork to them at 48", then 50", then 52", etc. and see what the difference is for yourself. Use some shoe boxes to stand in for structures - should give you a pretty good idea of what the viewing angles will be
Oh, I am going to experiment, totally. The house was built along time ago, and the room i am in is not really to code, so I am going to mount some scrap 1"x4" to the wall at varying heights. run my level off it to see how much the height changes from the wall to the middle of the room. Last night, after I completed the assemply of the sections, I played around with a few heights, using my tape only…it was getting a little late, so I didnt really get that into it. This afternoon, I will have a height and a bunch of legs.
I look forward to completing this part of the project, I will post my completed product for you to see and hopefully compliment.
Not sure exactly how you built your modules, but gray ceiling tiles might work as a substitute for the foam, assuming you can find them any easier.
There is an article in MRP 2010 where modeler Jim Six used this material exclusively for his roadbed and scenery element, I believe. His is a midwest theme, so the scenery was more rolling than maybe what you’re planning, but stacking the tiles should provide similar results as foam.
Also, when stacked, the exposed sides of the tiles tend to look like rock cuts, moreso than foam does.
Thanks everyone for the help. My bench work is mostly complete. I was able to sit in the center, sip a beer and day dream for awhile. I could post photos, but I am not sure ot the protocol, or if there is any interest. If desired, I can post some photos.
I was ble to drill some holes for the wires that will come some day too. I will check out that ceiling tile as well. thanks again, and let me know if you would you would like to see photos.
