My layout is currently built in sections. Each section has a pair of 14-gauge wires for the DCC bus lines, and another pair of 14-gauge wires for the Tortoise switch machine 12-volt power lines. The ends of the wires have ring connectors crimped on, and they slip over bolts that face down and are secured with wing nuts. It works well. However, between each section are four more wires with ring connectors on each end, and it is somewhat annoying to disconnect the wing wires every time I want to separate the sections.
I am hoping to find some 4-pin connectors that I can secure to the ends of the modules and just connect together. They need to be strong enough to carry the current of the DCC bus line, and not requiring soldering to the pins of the connector itself. Also, I need 8 joints so that means 8 male and 8 female parts… so I would prefer them to not be expensive.
Red and green can be found cheaper on Ebay. Not so the other colors, but I didn’t search extensively for those. I would choose 4 colors because Parkinson and his law never sleep.
I did not mention that, but the choices are 15, 30 and 45 amps. Don’t know why you would need more than 15.
Those that do crimping for important stuff, like heliocopter wiring, use ratcheting crimpers, not the stamped sheet metal tools you get at the auto store.
The Cinch-Jones connectors are long out of date. Our club modular layout uses Anderson Power Poles in various combinations - there are usually 2 or 3 DCC bus lines and in some cases a 4th line that is the DCC booster line to a power manager located on that particular module, as well as other bus runs for structure lighting and turnout power. Since the layout is actually only semi modular, the conenctions are arrange in such a way that the circuits found on every module line up and then the extras are stacked on teh ends, so if a mdule with a lot of extras is connected next to a simpler one, those extra pins won;t be used. In the case where the extras are needed but the adjoiningmodule does not supply them, we have various jumper cords that are used with some fo the smaller setups.
