Ok, so I am considering starting on a second layout for my son and I. the first was an attempt to get him and I into the hobby. well, we outgrew it quite fast, actually even before it was finished.
So, after looking at the reasons why we dont use the layout, we came up with a few reasons.
only one town, stuff comes and goes, but there is no feeling of delivery of either people or goods.
only one main line. limits how many trains can run at once without issues.
feels small. it started out as a 4x8 and then grew into a 4.5x9 with on section of line going behind a wall to hide the train as it “went to a different town”. although this seemed to work for a while, it just didnt as a train could not be allowed to go out there and stopped for a long time without a second train needing to use the same route. again due to a single main line. a second train could keep running, but it never leaves the one town on the layout.
So, to fix this I came up with a wicked nice layout design, problem is it needs a lot of room. and well, I am not allowed to have the room needed. So I designed a 9’x7’ hollow center layout, it uses just a tiny bit more room than the current 4.5x9 does once you consider how much room we use when we stand in front of the current layout. problem came with this 9x7 is there were a ton of turnouts and reach became a problem. I really need to keep reach minimum as Nicholas is only 7 still. we use manual hand throws. we find it makes operations better as we are constatnly needing to make sure the turout is the right way where as with electric, we might forget and cause problems. is a personal preference and seems to be working great so far. other issue is that with the large amount of turnouts, and the fact that I am not going to use non peco turnouts, there was a lot of $ that would be needed…$200 almost just in turnouts. I dont have t
Well I can offer up a solution to keep the town interesting, I’m about to start my 3rd layout and one of the things that I found was that I get board with the stagnant look of my town after only a few weeks so I’m going to make all my building lots with the same shape and size foot print so that I can make new ones and rearrange them when I’m board, I just pick one up, building, yard and all and replace it like big puzzle pieces, I’m starting a collection of interchangeable lots.
The things that will remain the same is the tracks and streets of course and the telepoles, trees and bushes not on the individual lots, in the end it will look like any normal layout but with the abaility to change its look and function as I see fit.
The thought process and practical learning experiences for the evolution of any layout are always interesting to read. Yes, I have a similar story about my son’s layout. Unfortunately it has been over 10 years now and I am certain I only remember the most gross details of how it came about. Similarly it would probably take a couple hours to write it out in a prose that could be easily read and understood.
The design and transformation took and entire summer, and even then there was an immediate change to add a “run around” track out on the main line. The story there is that one can plan forever and still overlook something significant. Overall though, I am still pleased with the design and two people can still go down and play with it for hours without becoming saturated.
Comments about your layout.
Nothing says the divider between the city and country has to divide the board evenly, go straight across the board (angled), or even has to be straight (curved backdrops can look less contrived.).
I think I would try to straighten the industrial tracks in the city a little more. Coupling cars on curves can be tricky to impossible.
Almost the opposite for the country side. Maybe curve the industrial track to run back to and then parallel with the backdrop divider. That would add some capacity. For that matter you could even run it through the divider and hide the tracks with a factory on the city side.
Do you really want a 3-way switch? They can be confusing for even experienced “older” people. What is the top most track from that turnout for anyway?
You realize the top most factory track (left) is a double switch back? Not really a problem just a bit unusual and one has to leave enough space empty on both the tails of the switchback to get at least a loco (and preferably one car) through to it.&
The two things I would definitely do are 1. make the runaround track longer and 2. get rid of the switchback.
I would also encourage you to add something more to the top side of the loop. Perhaps you could extend a branch from the existing track and make it a small mine spur. This month’s RMC has some GREAT small tipples you can model. Of course this orphans the barn. Perhaps the RR cut across the farmer’s land, or perhaps he found coal.
It would help if you could do without the roundhouse. Roundhouses eat lots of space on small layouts. Perhaps a 1-stall engine house? Engines could live outside when not being worked on.
Another idea: I have come to the conclusion that divider backdrops are somewhat of an eyesore. How about a tree-covered ridge going irregularly across. The trees will screen the view, but still allow one town to serve as a vague “backdrop” for the other. A big ridge isn’t needed, just a low rise that provides some mental and physical separation.
The deal with the farm is, it has to stay. its the wife’s request. the part with farm is actually up on a hill. and the land overlooks the two main lines. then the main lines actually go into a tunnel as it passes from the country to the city. thats what that green lines were trying to represent.
the idea of the mine isnt a bad one too…I could have that track go “underground” as it enters the hill the farm is on. I will think that one over.
the round house. I know it takes up a great deal of room. the son likes the idea of it, and I already have one built up and I have a atlas turntable in preperation of this layout. the round house I have is small, its only 7" deep and 7" wide at the entrance and 10" at the back. all the engines will stick out no matter what. unless I extend the back with sheds, which was a plan. I will mess around though and see how it looks. one thing that could be done if it was eliminated is I would be able to get to a 9x4, and that would make the building process easier as its closer to the standard 4x8 sheets of foam.
thanks for the ideas.
anyone see a major problem with using sectional and soldering them? I had issues with flex and the process I used for laying, i ended up pinching a curve too tight somehow in my last layout. I was thinking of the sectionals in order to keep myself from having that kind of thing happen again.
it looks like a good plan , and the suggestions others have made will make it even better . but i have to wonder if a better solution wouldn’t be to use the full around-the-room space you have (9x7?) but design a less complicated trackplan to fit it . you don’t need to use dozens of turnouts just because you have the space , trains look very realistic running through fairly empty country between towns .
I have this layout designed the way it is so that one side, the side that will be out into the room, the country side is very uncomplicated. this way trains can be just watched as they roll through, the city side is where I will spend most of my time and nicholas too i suppose. but I see him walking around as the train travels.
I do hear you wit the around the wall idea. it would be much easier to scenic too. I guess I will revisit that plan before any bench work is done. it is pretty simple too, but it has several turnouts that create a staging/storage area and thats where the $ started adding up. that layout plan does not have a roundhouse.
9 x 7 is pretty small for 'round the wall, and remember this thing has to be “gather 'round friendly” for the young viewers. That central pit can get crowded fast.
o: Nothing wrong with sectional track. You could even leave the joints alone and solder them if you have trouble. If the farm has to stay, perhaps you could give the farmer an outlet to his fields. Put a small bridge in so his lane can dip under the track. Maybe it was a concession the RR had to make.
I think that the plan “as is” has a lot of merit. I take it that in order for the room to be used for other purposes, the layout “on castors”, is essential, and an around the room layout is not reasonable. The entire layout might even be madr to fold up like a hard cover book. A 5 by 9 ft. ping pong table might even overlay the layout. Is this an HO or N scale layout? Even an HO layout is a little tricky for a 7 year old. The green track on the farm side could pass under the road. The train would disappear under the road and passes through a tunnel to the industrial side where it could go through the partition into factories and be hidden Or might switch onto a spur, or somehow switch onto the mainline on the industrial side by raising the factories so that they pass over the trackage below. You are going to have to electrically take care of “shorting”, on the mass of passing switches, double slip switch, and triple switch, which are too crowded. Could the trackage length of the be extended for the mainline “run around” at the bottom, by placing a doub;e slip switch on the left side of the layout. Is the triple switch absolutely necessary? You will get a lot of fun out of the small roundhouse.
Nicholas has been able to manage the 7 turnouts we have on the current layout. he has been running trains on it for almost 3 yrs now. so I am not too worried with this design.
the track is all level, the landscape on the country side will rise up and the farm will be on the hill. I thought of what you mention, having a track go under the hill and into the city but I wasnt able to agree with where it was coming out.
I didnt think I was going to have any shorting with the layout of the turout tracks, other than the turn table, I didnt think I had any reversing loops in there. can you tell me what you mean?
the 3way is there because, well I have one, and it also provided me with two storage tracks one on each side of the round house and at the same time continues to the round house. this will allow me to have a place to store nicholas’ passenger cars, 3 70’ cars and a place to store maggie’s passenger cars, 3 40’ cars that get pulled by her K-4. she doesnt run often so having a place to keep them is key.
what is the angle degree on a peco double slip? is it 19.5? or something else? the atlas program I used for this does not have peco in the list, so I would substitue a 19.5 degree crossing for a double slip if they use the same angle. I have found that the atlas #4 turnout is the same as the peco medium so i am able to use the #4 for the design. i was suprised when I printed a #4 out of this app at 1:1 scale and placed the peco medium on it, it fit in the lines perfectly.
Hey Kevin - Chris up in Burlington… We spoke about your garden layout before. [:)]
Have you thought about doing a “modular” layout? Yes, it would take time to setup, but you could do a shelf layout with additional “modules” that can be taken out when you want to run trains etc. Total setup time might only be ten or fifteen minutes and could be left up as long as you like, then taken down when you need the space again.
I’ll be coming down to the greater “Exit 7” area in a few weeks, probably next weekeend. I’d be glad to help you with a bit of planning and laying things out. There’s a few local people with layouts, perhaps I can give them a call and see if we can stop by…
What I do is solder the flex track as it lays straight and then I’ll bend the curve and tack/glue down. If theres still a problem, use a small straight section in between the curved sections. That will definatly help on the kinking.
on a completely different track (!) some of your buildings seem to be pretty small . if you haven’t already done so you might consider buying some of the kits you’re thinking of putting on the layout and checking their actual size . some manufacturers websites even have the size listed .
you don’t want to lay all your track and then find out later that the buildings don’t fit where you want them too
