[:D]HI Everybody!!
I got a Question for you I’m building a 2nd level to my layout. Now I know the best anwser is to build a helix, but I do not have the $$$ to build one, so can I construct a ramp? And if so what do I need to do as far as measurments and determining the grade, I’m working in “N” scale, so I will be using: GP40’S RS1’S AND SD90 MAC’S on the grade to the 2ND level.
Thanks for the help
TrainsRMe [8D]
Probably the best way to determine what your engines will do is to set up a long straight test track…maybe 10 feet. Raise it a few inches at the far end and see how well they climb…keep raising it a bit at a time to see haw far you can go and still have satisfactory performance.
underworld
[:D][:D][:D][:D][:D]
Thanks Underworld,
I will give that a try,
Make sure to test how many cars your locomotives can pull up that ramp.
I dont model in N so I have no idea what %grade that would be. XD
So where exactly do you live? Im in Portland Oregon myself.
TrainsRme-
I’ve just recently built a two and a half circuit helix for my HO shelf layout. It wasn’t as expensive as you might think.
My method was to use 5/8" Homosote, roughly $16.00 for a 4X8 sheet (only used half of it), cutting quarter circles and overlapping them at the ends to create the circuits.
I ripped a plank down to 1 1/2" strips and used these as supports with 1/4" dowel rods across to hold the roadbed circles. Each set of supports is secured to the layout table with L braces.
With the exception of the track; 20 or so curved pieces interspaced between sections of flex track; I’m calculating a total cost of under $20 and I still have a half sheet of Homosote for use in the second level benchwork. It’s not especially pretty but it’s certainly functional and a far cry less expensive than the $200+ deals I was able to find online. [:D]
I used the Atlas track to judge the shape of the quarter rounds, allowing an inch or two for overlaps at each end. At bit of Gorrila glue gave a good strong bond. Be careful during assembly to allow for enough clearance on the inside around the supports.
Good luck with whichever method you choose(ramp or helix).
Dave (dwRavenstar)
Thanks to JCtrain & dwRavenstar for your advise I will weigh my options and make the best chioce.
dwRavenstar, can you download a picture of your helix? I would like to see how you made it.
JCtrain, Hi there fellow Portlander I live in Beaverton not to far from Tanasbourne, Man don’t the Blazers SUCK this year or what!!!
Talk to you soon
TrainsRMe
