I was testing a new operation on my layout when I realized that two switches in the back of the layout are controlled at the panel. All switches are controled from there with LED lights to show direction.
There was an article in MR a while back showing how to install a REMOTE SWITCH on Tortorse controlled turnouts.
Does anyone no the issue or another source for this installation?
I’m having trouble on my end trying to understand your question but, as I interpret it you want to control one Tortoise from two locations and still have LED indiactors?
This is how I do it. And since it resembles a household three-way light switch (they are not marked on-off like a single pole is) I mount my toggle switch sideways since there’s no correlation to how the other toggle is set.
You have to connect the LED’s in the panel the way they are in the diagram.
The DPDT’s are connected together but HOW you connect them together is what is important.
No, read the description. He mounted the toggle switches so they throw left and right because there is no “wrong” position. The position of the toggle switches doesn’t indicate anything and doesn’t mean anything. The positon of the toggle has no correlation to whether the switch is normal or reverse. The LED indications are what indicates the position of the switch. If the LED’s show the switch is reverse and if you want it normal you throw the toggle. The toggle could be to the left or to the right, doesn’t matter. You throw the toggle and the switch lines. The LED’s indicate the new alignment. If you want to change it back, line either toggle, once again doesn’t matter which way either toggle is lined, if you change the toggle positon of either toggle it changes the switch position.
Dave H sumed up the operation very succinctly. [Y]
Nearly all of my toggle handles for powered (Tortoise) turnouts when in the down position I know the turnout is in the ‘normal’ route alignment. I can glance along the fascia and know that my routes are all good.
When it comes to turnouts controlled at two locations, as explained, the toggle handle has no relationship to the direction the turnout points are aligned, thus the LED(s) are important as indicator lights are on a dispatcher’s panel that may be 500 miles away from the actual piece of controlled track.
I have three such ‘dual control’ locations on my layout. Two are on long passing sidings where I want to be able to control the distant turnout without having to physically walk around a layout peninsula to ‘throw’ the toggle.
Some layout operators go so far as to have the remote turnout switch controlled by a key switch, and even further by introducing a time-delay on the switch motor. This somewhat replicates what an actual crew might encounter out on the road.
This panel is at the other end of the siding I show in the photo above. The far right toggle is mounted horizontally. The red or yellow LEDs tell me what the alignment is. IF I throw that right toggle the LEDs on both panels will always be in agreement. IF I throw the remote toggle, likewise the yellow and red LEDs will exchange as appropriate.
It is difficult to tell from this photo (those LEDs really ‘shine’ in the camera lens!) but the toggle handle on the far right switch is mounted horizontally.
The Remote switch will only be used during an op session by the operator working a long siding at the other end of the layout . This is why I said I do not need LED’s for the remote.
Are you saying in my present situation with the LED’s only (seperate Red and Green) on the panel that if I throw the switch at the remote location and change the turnout direction it will also change the LED’s on the panel to the correct alignment. If this is correct then all I should have to do is to hook up the DPDT’s
Adding a second (or third or fourth) DPDT switch, wired as a polarity reverser, WILL change the position of the Tortoise but will NOT cause the LEDs at the originating panel to also switch. You are adding another reversing switch AFTER the LEDs see the polarity coming out of the first reversing switch but not the second (see diagram above).
The indicating LEDs no matter their location have to be wired AFTER the last reversing switch and BEFORE the Tortoise.
Doesn’t matter. If you take two ordinary LEDs and place them ‘back to back’ they will act the same as a bi-color LED. The bi-color ones simply put them in the same, tiny package. I think my diagram says bi-color LED or two single?
No matter what you do the LED indicators have to ‘read’ the same polarity that the Tortoise is getting. If you wire your LEDs ahead of the last reversing switch they will NOT stay in synch with what the Tortoise is doing.
That is why I use a four conductor wire between the main panel, then to the remote panel, then ‘through’ all the LEDs as necessary and finally to the Tortoise.
I’ll try to make up a better sketch than my hastily drawn one above if you think it will help you get a better idea.
Note: In many of my recent installations I’ll use two bi-color LEDs (for yard trackage I found red/yellow LEDs and mains I use red/green) so that the ‘model board’ or track outline will show exactly what the line-up is.
Each LED in series will drop the voltage to the Tortoise, IIRC, .8 volts so there’s a limit to how many you can have in series with the Tortoise.
Of course you can use the auxiliary contacts for any panel or signal indicators and not run this risk.
Familiarize yourself with the Circuitron instructions:
