I do not understand the wiring of the 3 rail. I am running lionel 0-27.
Can I do a reversing loop? If so how?
arcanggell,
The beauty of a 3 rail reversing loop is the middle rail never crosses to the other side as in 2 rail (which causes a short between the common and supply of the transformer) so it does not create a short circuit. Thus no special wiring is needed to create a 3 rail reversing loop. The 2 outside rails in 3 rail are both connected (typically) to the common of the supply.
Welcome to the CTT Forum! [#welcome]
so I make a loop and it works.
thank you, so much.
The really great thing is,if you have non-drailing turnouts they will throw automatically giving you hands-off operation.
Ed
Yep, all you have to do is make the loop. Nothing more.
