I am baffled with this one. Check out my track diagram. The red dots are gapped rails.
I have three Walthers Shinohara 3-way turnouts lined up end to end on my DCC powered layout.
My auto-reverser, a Digitrax AR-1, is clicking as a loco crosses over the second and third 3-ways, as you look from left to right. Is the gapping that is built into the 3-ways causing the AR-1 to reverse polarity. I hear the clicking twice, once on the second turnout and once more on the third turnout.
At first, I wondered if the AR-1 was acting up by through various tests and swaps of another known good AR-1, I am convinced that it is not an AR-1 issue.
I would not expect to hear any clicks as the loco traverses the three 3-way turnouts.
I also have another curious issue. I have a BLI E7 that prompts the AR-1 to click when I press forward and again when I press reverse on my throttle. This does not happen with other BLI E7s inside that reversing section. I try that BLI E7 on a different reversing section on my layout (a straight section of track) and that clicking on forward and reverse does not happen.
HELP!
What is going on here?
