I have the 3454 Automatic merchandise Car. it is in good shape
It will not operate the unloading chute, although it does uncouple. There must be some kind of a short, but if the uncoupler is working, wouldn’t that preclude that there is no short. The shoes seem to be functioning well-- they make contact on the track and the wire from the electromagnet at the coupler does not seem to be broke or unconnected.
After several attempts thinking only one coupler worked, finally the second coupler started to work.
And then miraculously, when I went to unload, the mechanism started to work and kicked out those cubes like crazy. So that is working now
But — the door won’t close right now. It seems restrained by a spring or some kind of a catch up inside the car, and the coupler in fact does uncouple in the unloading operation
The Sept '94 issue of CTT’S has an article by Ray L Plummer on servicing the 3454 automatic merchandise car. One of the troubleshooting hints is " Door action slow or incomplete- Check for bent or loose door guides. Clean door slots. Lubricate pivot bearing."
Other advice- Do not oil solenoid. Contacts on shoes should be clean and shiny.
That’s probably the other coupler or it’s connection to the sliding shoe.overheating.
If one coupler activates while operating the unloader, it is functioning properly. This is a side-effect left over from the prewar era when the couplers were reset/closed by gravity. The switch to magnetic plate couplers starting in 1948 eliminated this issue for operating cars.
