Hmm, well, so much for that theory, they are likely identical, what I have and what you have. The only difference is probably that the 5mm ones I used are in lesser quality models with not so awesome light pipes which attentuate a good bt of the light. If I could dig one out (LED, not the loco) I could power it on my workbench and see how bright it looks with just the bare LED.
The Stewart switchers, which have 3mm versions - the light pipe lenses used for those headlights would probably qualify as optically clear, looking through one looks the same as just looking through air. The Walthers Trainline FA headlight lense, where there is a 5mm YeloGlo, well, you see light through it, you can;t read or see any detail. Same with the Atlas/Kato RS-3s - I do cut down the light pipes quite a bit, since the originals both reach to the center of the loco where a single bulb lit both headlights, but still there is a couple of inches of light pipe from the LED to the actual headlight, so all you see is the glow. I do lightly polish the cut end of the light pipe to help lkight transfer, but any interface between materials, liek the case of the LED and the light pipe plastic, is going to cause a significant loss of light output. The end of the light pipe and LED are covered in black shrink tubne, so no light escapes into the loco to shine through the shell. The extreme brightness of the 5mm YeloGlo may actually be a benefit in installs like that, but when it’s in direct view or through a quality clear lens, way too bright.
I’m not very good at photography either but working on it. This I my Kitbash Lounge car with 10 wide angle Warm White Super Bright LEDs, 9 using 9.1KΩ resistors and one over the Bar area with a 4.7KΩ resistor.
Click on the photo to enlarge.
The newer Super Bright LEDs are very bright and I end up running them at very low current as you can see on my Mel Meters.
I use a 2KΩ 20 turn trim pot in all of my passenger cars to individually set the brightness for each car through the end door.
I recall posts on the forums where modelers used MV Products to hide the body of the LEDs. They removed just enough of the silvering from the center of the back of the lens to allow the light to come through.
I have had a situation where on a passenger diesel (like an E-unit) the lower main headlight seems OK, but the strobe/Mars light effect in the upper headlight seems too bright (or just annoying). I’ve used transparent yellow paint to tone down the LED a bit. It makes the color more yellow-white than it was, but it does take the harsh “edge” off the brightness.
BTW if these engines are DCC, there are some (many now?) decoders that allow you to adjust the maximum and minumum light brightness via CVs.
I have been using 3mm warm white LED’s I pulled out of strings of Christmas lights as direct view headlights/Mars lights behind a lens made from Testors Clear Parts Cement in several HO scale EMD F unit diesels and have been extremely happy with the results. First, the inverted cones molded into the tops of the LED’s look more like sealed beam headlights than any other lamp/LED I have ever tried, even when off! Second, these LED’s give a off a slightly yellow glow that is just bright enough to actually illuminate the track in front of the loco for about 100 scale feet. They’re not too picky either, working with resisters anywhere from 470 ohms through 1K ohms. As I have installed DIY stay alive circuits in most of these locos, it is amusing to watch how long the headlights/Mars lights stay on long after the layout has been shut off.
Very interesting approach to the lighting issue. I am a bit surprised that you are able to fit a Christmas light inside the shell based upon the size of most Christmas lights.
You have to disassemble each Christmas light in the string to get to the bare 3mm LED’s. First, remove each Christmas light from its socket in the string. Depending on the brand, you may or may not have to break the clear plastic dome away from the opaque plastic base (some are just a friction fit). You then straighten the bent over LED wires and slide the LED out of the base. You now have a diffused light (inverted cone) 3mm LED.
I don’t like having wires connecting my Loco body shells to the chassis, so I mount my LED headlights in a manner similar to the original Athearn Blue Box headlight. I cement a piece of sheet styrene to the front end of the F unit chassis with a slight tilt back to clear the nose of the body shell. I then place the shell on the chassis and use a thin tip marker or sharp awl to mark the headlight/Mars light centers on the piece of styrene. Next, I remove the body shell, drill out the LED mounting holes, and press fit the LED’s into the styrene support. I temporarily reinstall the shell to verify the LED’s are centered and as close to the inside of the headlight openings as possible. At this point, I remove the shell once more to glue the LED’s in place and complete the DCC wiring. A little flat black paint on the rear and sides of the LED’s keeps light from bleeding into the cab. Finally, I use Testors Clear Parts Cement to create headlight lenses in the body shell. Once dry, I reinstall the shell and place the loco on my layout. The inverted cone of the LED looks all the world like a bulb within a sealed reflector lamp mounted behind a separate glass lens. These warm white LED’s also produce the warm yellowish glow of an incandescent headlight and will actually light about 100
Those are indeed good prices on pre-wired LED’s. However, these are not the “diffused light” inverted cone LED’s you find inside Christmas lights. The body of the LED is molded with an inverted cone in the top of the LED (not round or flat but more like a funnel). The idea is that most of the light traveling up from the LED element is reflected out the sides of the LED. The tip of the cone does not reflect much so you still get a narrow and bright light coming straight out the top of the LED. The effect looks quite like an incandescent sealed beam headlight as you can see in the photos below. The headlight is at full strength while I tried to get the Mars light at partial illumination to illustrate how narrow the beam of light coming out of the top of the LED can be. The 45 degrees from head on shot also shows the Testors Clear Parts Cement lenses (sorry its a bit blurry).
I bought several 100 LED strings of Christmas lights for $6 per string which works out to 6 cents per LED (I don’t charge myself for labor).
I’m sorry, I should have searched a little more carefully. I understand what the ‘diffused’ LEDs look like. I believe that these are closer to what you want. Unfortunately they are quite a bit more expensive if you want them prewired:
I have always used difffused LED light for open surface viewing such as control panel mounted LEDs, trackside signals, etc. The light can be viewed from all angles. In other words, a diffused LED spreads out the light beam due to the opaque lens.
On the other hand, a non-diffused clear lens LED has a narrower beam width and is best used for hidden beams such as locomotive head lights, Mars lights, ditch lights, etc. In other words, LEDs with non-diffused clear lens have a narrower beam width, and the light beam is sharper.
The Christmas light LED’s I like do not use a frosted or translucent lens to diffuse the light. Instead, the top of the clear lens has an inverted cone molded into it. Light from the base of the LED hits the surface of this cone and is reflected out the sides of the LED lens. However, the tip of the cone does not reflect light nearly as well so a narrow beam of light still escapes out the top of the LED making it perfect to simulate a sealed beam headlight.
