Hi all,
I decided to build a new locomotive no. 8 for the Bradford Valley Lumber Co, as I wasn’t satisfied with the current one (a 35-ton diesel critter). I’ve always liked the look of the Bachmann On30 2-6-0, however as you can see below, the locomotive itself already takes up most of the turntable.
As such, I decided to convert it into a 2-6-2T saddle tank engine. Although not following a particular prototype, it’s inspired by this Alco engine: http://narrowmind.railfan.net/262T-ALCo30-42.jpg.
After figuring out how to get the shell off, I removed the domes and other details. These were put aside for later use.
My next step was to construct the saddle tank. On the original model, there’s a short section in front of the cab where the running board is at the same height as the cab floor, then the rest of it runs a bit higher. As such, my original plan was to have the saddle tank stop at the end of the higher section, then bring the cab forward to meet it.
I obtained some 4cm diameter PVC pipe. After cutting that to length, I cut it in half lengthwise. The resulting pipe was a little bit low, so I decided to raise it by about 5mm. To this end, I used some 3mm x 1mm and 2mm x 1mm styrene strips. I glued them e
