I’m going to have a lumber mill big enough to need a dedicated switcher. I need a lot of different sized lumber.
The trouble is my mini table saw will only cut as low as 3/32". What I would like to do is attach a 1/16 strip of metal to the rip fence so I can make stacks of scale lumber.
I have an Irwin that opens to 4 1/2", also one that opens to 12 1/2". You could check with your local hardware store and see if there is a mid-sized one listed.
Stacked lumber is pretty much a cube cut to length 8’ to 16’. Unless you plan to do indicidually stacked boards, a block of wood, scribed, should do for the stacks and purchase a few scale pieces for extra detail effect.
Awhile back I bought a Harbor Freight Mighty Might table saw for my hobby bench. I didn’t come with a fence so I made one from Basswood.
The blade height is fully adjustable from 0 to ¾”.
I’ve used it quite a bit on both Basswood and Styrene and it has worked out very well. The Basswood fence came out a close fit to the top of the saw but a strip of 3M striping tape give it some friction to keep it in place.
The saw is pretty good, I cut a 2” diameter schedule 40 PVC pipe by rotating it.
If I understand your question correctly, I would use wood rather than metal on your fence. That way if you slip the saw will be chewing into wood rather than metal.
You might try this:
Get two or three small counterunk-head machine screws.
Fashion a plate for your fence using wood thick enough for the screws to be countersunk a bit deeper than the exposed surface of the wood.
If possible, clamp the plate to the fence and drill at least two holes through both, using a bit size that will allow you to tap the fence holes with the appropriate sized tap. Best to use a drill press for this operation, if you have one.
Tap the holes in the fence.
Open the holes in the wooden plate to a close clearance for the screws, then countersink the holes.
Screw the guide onto the fence, and you’re ready to go!
The holes in the fence shouldn’t interfere with the normal operation of the rip fence without the plate, and you can replace the plate any time you need to.
If that’s too much work, spray the back of the plate with an adhesive like Super 77 and slap the plate onto the fence. Remove it later using a putty knife. You’ll probably have to clean the fence face with some sort of solvent - gasoline or mineral spirits, I would guess.
Back in the 70’s my mother in law bought me a set of brass bar clamps from her Avon pusher. They are a little over 12" long with a sliding stop and an adjustable block on the end. I have been using them ever since.
I don’t know if they are still available, but if you want something durable that you won’t wear out, you might look for them.
I’m also working on a lumber mill scene. I started by using strips of styrene, cutting them neatly in lengths and piling them up. Did one or two piles, and painted them a “sand” color, and they looked nice. I model HO, and I find that actual wood does not scale down very well because of the grainy and porus aspect of real wood. But the worse was doing the cutting, gluing and piling of the boards. I lost patience and bought the Atlas milled lumber kit…
I considered it. I even bought a pack of ultra-fine brown sharpies to make the cuts. As a contractor for 15 years, I got to see a lot of lumber yards, and only rarely are they stacked evenly–and then only when banded.
What is going on at this lumber mill is boxcars are being moved from place to place while workers fill orders. There won’t be any stacks left unturned.
But this not the only time I would use scale lumber. I’m constantly building things for the town. I can’t rely on 9x9"posts to be good for everything.
I’m not worried about cutting my fence–but I am worried about friction when trying to push rough-sawn popsicle sticks and coffee stirrers through the blade.
I just got some Super 77. If I find a piece of metal, I might gove it a go.
Now, anyone know where I can find a 1/16 piece of metal. I’m not even sure where to start.
