A few questions about scratchbuilding the Burlington, IA station
First off, does any manufacturer make wall sheets for lannonstone (aka field stone)?? Next, the plans I have for the CRI&P-CB&Q station in Burlington have a scale of 1 inch = 30 feet. How do I convert that to HO (1/87.1) using a scanner? Also, since I’m going to be putting a nice interior of this structure in it also, what is a good way to model Terrazzo flooring and marble walls, not to mention asphalt tile floors??
Thanks for any info,
The Burlington Route fan[;)]
Chris,
Check out the Plastruct product line. They’ve got dozens of types of textured plastic sheeting in several scales. Now that Holgate & Reynolds is no more, they’re the largest manufacturer for this sort of thing, and I use their brick sheets for all sorts of things. They make at least three varieties of field stone and cut stone sheets in two scales, so they SHOULD have what you need for the fieldstone. They also make several sizes of tile which should be helpful (Evergreen also makes tile).
As for simulated marble, check the craft section of Hobby Lobby. There are several different products that can be used to create faux marble finishes, in several colors. The easiest is a one step spray can. I’ve never worked with any of these products, so I really can’t comment on which one is best.
For asphalt tile, you’ll have to dig deep into the Walthers catalog. I’m sure one of the German scenery manufacturers will carry something similar to what you need, but it’s not cheap. Since you have a computer, you might want to experiment with creating your own patterned flooring DECALS. Remember, the cheap & easy way to make “white” is to actually print it as 10% grey!
Hope this helps!
CJM89,
Someone will probably suggest you just use a pair of dividers to pick off major dimensions against the scale, then use an HO scale rule to lay out your building parts. I would like to suggest that you take your plans and a good HO scale ruler to the local Kinkos, Office Depot, Staples or similar store that has a copier with an enlarging feature, rather than a plain scanner. Since HO scale is approximately 1 foot = 7’ 3", if my arithmetic is correct, I think you can enlarge your plans to slightly less than 414% to near HO scale, possibly in two or more steps depending on the copier. Use your HO scale ruler to check the enlarged plan to see if it’s acceptable. There may be some distortion.
Bob
NMRA Life 0543
CJM,
Would something like this from Chooch work for the walls?:
http://walthers.com/exec/productinfo/214-8300
No, field stone is less “square” looking than brick or that stuff. I wish I knew how to explain how it looks or at least post a good pic.
cjm89,
Let me make a supplemental suggestion if you have problems blowing it up to about 414% (my calculated number is 413.3%). Go to an architect’s/engineer’s supply store (usually this is a place that does blueprints) or a college/JC/CC bookstore and pick up an inexpensive engineer’s scale and an architect’s scale (plastic will do just fine-lots of times these are on sale at the end of the academic year). These are triangular shaped rulers with 6 scales on them. The architect’s scale is in fractions of an inch per foot (such as 1/8"=1’, 1/2"=1’, etc., useful for elevations and floor plans) and the engineer’s scale is in decimal units (useful for site plans in scales such as 1:10, 1:30. 1:50, etc.). You want the scale on the engineer’s scale marked “30” which is 1:30. Measure the dimensions and write them on the base drawing that you are using next to the appropriate line. You don’t have to get within a fraction of an inch to be right–remember 1" in HO scale is 0.0115 inches, imperceptable to the eye, and no one, and I mean no one, in their right mind is going to put a rule to your model and then go out to Burlington and field-verify your measurement
It seems for my skill level I always bite off big projects…[:P]
I think the building’s length is in the 260’ range, that would be about 6 40’ boxcars plus a caboose…so it’s still not a big as some models. (imagine a G scale model of it though…!)
