Stopping and waiting five minutes is for operating in ABS territory. When operating in CTC, a numbered (intermitant signal) with a red aspect is a stop and proceed and movement is made at restricted speed. A number plate signal with a “g” on it and designated in the individual subdivision instructions(timetable) as a grade block displaying a solid red aspect is a proceed at restricted speed. These signals can also display a flashing red aspect which is to proceed at restricted speed as well. An absolute signal(at control points or interlockings) displaying a red aspect is a stop signal and requires authority from a dispacther(control operator) to proceed past the signal and that movement will be made at re
But a “G” sign on an automatic block signal is not stop and proceed but rather to continue at restricted speed prepared to stop short of an obstruction, train ahead or whatever might be there.
As for fog, as I have noted before, “when in doubt, the safest course” should be taken. I believe that the old adage of going no faster than having the ability to stop within sight distance. is the most restrictive action short of stopping. The more mainline, i.e., multi track, signaled, radio communications, no grade crossings would allow for a better speed than a single track, dark and grade crossings every couple hundred feet. But it all boils down, too, to how well the engineer knows the territory, knows the train, and knows himself.
It may have changed, of late, but it used to be that the “G” applied to heavy freights only–which would have been difficult to restart after stopping on the upgrade. All other trains were to stop and then proceed at a restricted speed.
Tis the textbook definition of restricted speed. If you’re required to follow restricted speed, that’s what you do. But if you aren’t… go the maximum permissable speed you are comfortable with.
Most of the rule books I’ve seen (and I know, I haven’t seen them all) from about 1960 give or take, changed the grade signal with the “G” plate to a restricting signal. Any train or engine could pass without stopping. Some railroads used a “P” for permissive to allow trains to proceed at restricted speed without having to stop first.
The same goes for waiting 5 minutes before proceeding at a stop and proceed. Many of the later books had dropped the requirement. One book from the 1940s had that provision only where authorized. So you could have one place that had to wait 5 mins and others that didn’t on the same railroad company. Go back to some really old books, and
