I just read a post about wires on poles and I just wanted to ask, when you see a really good model picture, what do you look for to find out wether it’s a model or the real thing? I usually check the couplers
I’m so cheap, I checked this post to see what you were gonna send me… oh well.
(good suggestion however)
Some of the photogrphy I have seen is so good, that I just have to rely on the fact that its in a model magazine and about some ones layout or in trackside photos, to realize its a model.
Although I did like the June 1999 issiue of Model Rairlader however. It had a soo line F unit on the cover and Was a very convincing pic. Then I saw the alien in the Cab. Some one has a sense of humor. I love it.
James.
I usually look at the track or the handrails on the locomotives (if it has handrails) to tell if its a model or the real thing. But the couplers can also be a good giveaway.
I usually look at the wheels - if they’ve got massively overscale treads then it’s a model. Though having said that, it’s getting harder to tell the difference with the latest crop of models with nearly scale treads.
I look at the people…almost invariably the worst aspect of even a great layout.
The sky is often a giveaway if it is a fake although some photos are taken outdoors.
Failing that the wheels and couplers in smaller scales or the people in larger scales.
All of the above plus code 100 rail in HO, windows and structures, trees among others.
The foliage is always the giveaway for me; real leaves have a semigloss or even gloss finihat results in extreme contrast between highlight and shade, while the green foam we all seem to use (combined with unnatural lighting) results in very flat-looking greenery. I’m wanting to find the solution to this dilemma, and I’m experimenting with varnihinned with turpentine as a scenic adhesive, since this imparts a sheen. I’m thinking that mixing in some oil colors, to add a dark green wa***o the effect, might be what it takes, but the jury is still out.
I also can always tell model figures when I see them, and they have the opposite probem: too much plastic sheen, too much gloss. Painting with flat acrylics may help, and possibly weathering with chalks would be in order.
Flanges. The RP-25 flanges on models are bigger. In prototype photos, they’re almost invisible unless its close up.
I can usually tell if the train’s a model or a real one by several things
- People on a HO Train? Don’t think so… [;)]
- The doors on the side of the engine look a little too realistic
- The trucks sort of appear to be rusted, with lots of mechanical features
- Unless it’s a really good paint job, I never really expect a train to look shiny.
- Usually the tracks are a good giveaway
- Like everyone said, the couplers.
grass, weeds, dirt, and trees
