A (Mostly) Scrapbox Plow Mogul
A while back a fellow hobbyist sent me a really scruffy set of 5th gen Bachmann Big Hauler drivers, gearbox and motor. I had a nos Delton c-16 chassis here as well. So I stuck the two together. !(http://i592.photobucket.com/albums/tt7/tigerlillie06/His Stuff/P1120023.jpg)
Added a Bachmann smokebox and $2 worth of pvc!(http://i592.photobucket.com/albums/tt7/tigerlillie06/His Stuff/P1130023.jpg)
A mixture of Bachmann and Kalamazoo domes, a c-16 cab, and custom rods made from brass box and c-16 bits. !(http://i592.photobucket.com/albums/tt7/tigerlillie06/His Stuff/P1010020_02.jpg)
It started out to be an 0-6-0, but since I don’t have any yards to switch, I decided that a Mogul would be more useful. I found this pic of a H.K. Porter, and decided to shorten mine up similarly
The tender is a Delton one that I had previously cut the flare off for another project. I made new extensions from brass and B’mann running boards ala D&RGW K-27 #463s only smaller.
Since this one will be battery op, I chopped a hole in the tender deck to mount a box with the charge jack and on/off switch.
And the air tank makes a nice cover
Did I say plow? I should have said P-L-O-W!!! As in an Aristo-Craft replacement blade from
Wow. Big plow-I like it, it looks cool. How do you like the critter control?
I won’t know until I can get a battery, charger, and stuff – which might not be until April, depending on the price.
I was thinking of eventually building a 2nd identical loco, but with a road pilot and then switching off the tender summer/winter. Since the plow is now permanently mounted.
(Except for maybe the plow) I think a basic post-1900 Mogul could make a really decent production model for somebody. Smaller than the Big Hauler, bigger than the c-16 with a shorter wheelbase than either. Pretty much what the mining mogul promised, but failed to deliver.
You think the newer run is any better?
I like it!!! steam and snow look great together!
I would put as much weight into it as you can if you want to really push the white stuff.
My basically stock LGB forney is too light to really work hard pushing snow and the stock big hauler has has less traction. I added another 4 or 5 pounds of lead block onto the running boards to see what happens and was supprised at the improvement!
–Eric in Phippsburg Maine
