Way back when, my Dad and I laid all our track by hand. We used ties that came in a roll and looked like they were made of some type of card board. Does anyone else remember these or should I increase my daily Geritol intake?
South Penn
South Penn
Perhpas no Geritol needed maybe. I’m 56 and my first mail order of track I received (1970’s) had cardboard ties held on to the rail by what looked like staples. I was surpised, and not pleasantly. I do think it was the tail end of cardboard tie track, I never received any after that. I didn’t see the ties in a roll, but sounds similar.
Atlas Black Fiber Tie strip, $2.85 for a 25’ roll in 1952. 36” iron or maybe mild steel rails were 10¢ each. Don’t remember how much a bag of spikes cost. I hand laid all my track and made my turnouts. Started out with HO scale at the ripe old age of 14 in El Paso Texas funded by my paper route.
My first power supply was a Lionel O27 transformer from my first train set when I was 8 and a 4 amp selenium rectifier, I was in hog heaven! My first locomotive was a MDC 0-6-0 kit that cost $6.85 from H&H Hobby Shop on Pershing Drive owned and operated by John Henson and his wife.
Edit: Like Frank says below brass rails were available but they cost 3¢ more than the rustble rails and on my 75¢ per week paper route the 3¢ more per rail was too much for me. I think I can remember the price written on the box of tie strip at $1.25, not $2.85. The tie strip wasn’t cut for curves in 1952, that must have come later. I used wire cutters to cut the tie strip for curves.
Mel
They were fiber ties, with holes pinched out for spikes, they were also cut every fourth tie on both sides staggered so You could bend them in a curve. They came in 25ft rolls from Atlas. They were made to go with Atlas code 100 brass track, that were sold in 99ft bundles. Spent many an evening hand spiking track on cork roadbed and in curves, I used Tru-Scale plain milled wood roadbed…spikes would go in without splitting the wood, without pre-drilling, thank God…LOL.
Had a fairly large three level layout built with all hand layed track. Started on it in 1955…I was 13 yrs. old…My Dad was not into trains… I learned on My own.
Take Care! [:D]
Frank
How many of you tried to apply ballast to that fibre tie strip and found that it curled up when it got wet?
Charlie
I never used water… I did a three foot section at a time or less and pre-cut the tie strip, painted the cork roadbed with dark grey enamel paint, layed the tie strip on the painted cork and put a few staples in the tie strip, then poured the ballast right on the wet paint and ties. Then started spiking the track. The paint took close to an hour to dry back then, more than enough time to spike a three foot section…once dry…it held everthing in place quite good. I even got many comments on how good it looked…I was shocked myself…I thought it would be messy. I used John’s ballast back then…I believe that was made from cork…10cents a small box.
Take Care! [:D]
Frank
The fiber ties was common and there was ways to ballast the track without the ties curling. IIRC it had something to do with the white glue mixture and it was thicker then the mixture we use today but,workable…
I didn’t do ballast until the mid 60s and by then Atlas was using plastic ties so I didn’t experience water warping the fiber. I used white glue and glued the tie strip to the roadbed then spiked the rails in place. I don’t think the roadbed was cork, I just don’t remember. I was thinking back and I think I was wrong on the cost of the rails, I think the rustable rails cost 5¢ and a brass rail was 9¢.
Mel
My Model Railroad
&nbs
Back then, I think it was TruScale who sold a sort of liquid ballast. It was just gray paint with granules in it, so when it dried you had a granular surface.
Those were the days!
I am almost (but actually, not at all) ashamed to say that I still have a full roll of the Atlas fibre tie material like new in its original box. It is true that water can make it warp and curl but it is also true that when the material was in common use, few if any used water based material anywhere on a layout, much less in laying track. Shellac, baby!
Atlas also made built-up and kit turnouts using that same fibre tie material. In fact Atlas also made a track gauge using the fibre material, and yes I still have a few of those around here somewhere.
I have some recollection that O scale guys used the Atlas fibre tie material to make picket fences back in the day.
Don’t even get me started on Baker couplers …
Dave Nelson
Funny thing, this week we just received another box of Atlas fiber ties in the original box at Boothbay Railway Village. The marked price was $1.00. It is in good shape, and we are going to put it on display on the history shelf.
Thanks for bringing back some great memories. I was about 8 when I started helping my Dad. We didn’t have any roadbed or ballast that I remember. We spiked everything to pine boards that my Dad cut on a bandsaw. And we used brass rail. We used to clean the rail everytime we ran the trains. My job was to do inside the tunnels as my arms would fit inside them.
I don’t think our ties were pre-cut. I remember learning how to use a pair of ‘side cutters’ and cutting the link between the ties at about every other tie. But only on the outside of the curves.
We used window screening to form the landscape and covered it with plaster. ( on a second layout we used paper mache )
I don’t know where the switches came from but they looked just like the pre-DCC Shinohara switches that I use now. They were controlled by choke cables. ( I had no idea where the cables were from until I was 15 and started working on cars. )
Again, thanks for the memories.
South Penn
Hey guys!
Like a famous crooner sang, “Thanks for the memories…”!
I find it very interesting to learn how things were done ‘back in the day’.
Dave
Yes, it was called fiber tie strip and I too still have a roll of it. I bought most of my rr track from America’s Hobby Center in New York City. A brass turnout on fiber was about $1.25 and I put mine right on the plywood or pine board; didn’t know about cork and probably couldn’t afford it. This was in the 1950’s and I was about 13 at the time. Don’t miss that stuff!
-Bob
Gee,Frank, I think that might have been the way my Dad ballast track…My feeble minded memory stumbles and trips in that area even though I remember Atlas flex track and switches with fiber ties my dad used and they track was ballast and the yard was ballasted with cinder ballast…
Now I’m a’ thinking the glue mixture method came with the plastic ties.
If anybody wants some fiber tie strips, a local hobby shop in my area found a roll in a box of used stuff they bought.
I can take us back a bit further to 1945 with my first train which was Lionel O27 three rail. My Dad gave it to me for Christmas 1944, I have no idea where he got it, everything was rationed because of WWII. There was no track available and my Dad wanted to set up a large dual track loop shelf type layout in our basement for me.
He got the machine shop where he worked to make a die of an O gauge rail. It consisted of a solid metal bar of about 10” long by 2” x 1¼”, the machinist cut a grove down the center of the bar the width and depth of a Lionel rail. He made a metal “T” section that would drop down in the slot. MY Dad would cut up tin cans (food cans) to form several strips of tin about an inch and a quarter or so wide by 10” long inches long. We would place the tin strips over the slot and drive the “T” into the slot with a hammer forming a U shaped rail. We would trim the bottom edge leaving a slight flange and used carpet tacks to nail the rails in place. We made “joiners from ½” wide strips of tin in the die then squeezed them enough to slide into the rails and solder them. That’s how I learned to solder at the ripe old age of 8 by using a baseball bat sized soldering iron and solder dipped in acid to make a solid joint.
I have three unused boxes of those tie strips.If I decide to use them I figure a few coats of flat black will seal them.
Yup, Atlas fibre tie strips… One major problem, they absorbed humidity like a sponge, and any use of glue/water mix for ballast adhesion was often a problem.
Maybe the humidity/tie strips is the reason I remember having a lot more connection problems and derailments back then. Our trains were in the basement.
South Penn
