Accucraft East Broad Top Mikado
Note: To operate in a rempte control mode is very easy.The RC RX & Battery packs are double A size nickle hydride @ 2300 Ma which will run you all day without charging.The servos I use are mini size & have avery good torque load of 60 lin ounces.I mount mine using 3-m
double sided tape.Control linkage are flex RC aircraft throttle cables (no need for a lot of linkage rods). I have this system mounted in my Accucraft 3 Cylinder Shay.The only gear in the cab is 2 Servos.
Great Mikado to see running.Regards W.McMillan in Ottawa,Canada
