Looking for help and suggestions on the best way to add a headlight to this tired old 2-4-0. Anyone have any suggestions?
Did I add this to the wrong forum?
Yes it can be done. Of all the cheaper Lionel plastic steam engines, this one is a little more work to get apart because of the valve linkage which attaches to the plastic body. But it does come apart. Of course, I repainted the loco, painted the trim and molded handrails, and added a great deal of weight to the main sheet metal chassis.
You’ll have to take the loco apart, and solder a couple of new wires off the positive and the ground wires. You could add a 6 volt bulb with leads. What I chose to do what to install a mini-socket into the molded headlight fixture. This makes for changing the bulb much easier because you will not have to take the loco apart.
I used a mini socket for a E5 T-1 3/4 Radio Shack bulb. The fixture has slightly long metal leads which I clipped to make them shorter. I’ve had trouble getting the wires to solder to these fixtures. So I take a small file and roughen up the metal fixture leads and then the wires solder to them nicely.
I painted the silver bulb socket black and made the wire leads long enough so I have room to get the chassis and shell back together. The socket and the mini-bulb will stick out a little bit from the molded in headlight box on the loco shell. I cut a piece a of black drinking straw and slipped that over part of the light bulb and into the molded headlight box. I had to slit the piece of black straw length-wise to it would fit into the hole of the headlight box.
Depending on how how bright you want the headlight to be (and how heavy yopur typical train is) you can add either a 6 volt or 12 volt bulb.
The 8300 is a different looking small steam loco, from the usual small plastic steamer Lionel MPC put into starter sets. A little paint and some highlighting, adding a better metal bell and steam valve to the loco with engineer figures in the cab - and you can make this loco look so much better. Adding weight to the frame will have it pulling trains you never could before.
