Puting together some old accurail coal hoppers. According to my coupler gauge, the couplers are a tad low. I figure I can fix that by adding a really thin washer between the trucks and the bolsters to raise the body up a tiny bit. Where do I get some super thin washers of an appropriae size to do this? I actually thought about making some out of cardstock but really don’t want to invest the time and trouble to do that.
Have you watched Daniel Cortopassi’s reviews of freight cars such as ScaleTrains, Tangent, Moloco … you name it. I don’t think there is one freight car he hasn’t reviewed that didn’t have one coupler that didn’t match the Kadee heigh gauge. For some reason, it seems to be nearly impossible to get Kadee’s always able to match, out of the box.
Hah hah! Reminds me of myself. I’ve used copy paper boxes to store my trains that I have collected over the years and moved a number of times. My favorites are the harder to find paper boxes sized to hold reams of legal sized paper because they are bigger and can fit more. I still have some from when I lived in Rottenchester NY and got boxes from a guy who worked at Xerox in Webster NY.
Likewise, looks like Dan has been stock piling trains for some time as well.
He has new video’s with his new wife sitting on the sofa unboxing freight car after freight car. Heck, when I moved, I had lots of boxes like that - I could have done an unboxing series like that too! I imagine hundreds of guys could!
It would be interesting to see Dan show his layout plans and some construction progress video’s.
Heh - I do not miss much about work since retiring in 2013, but I do miss the access to copy paper boxes – both regular and legal size paper. Our office staff knew I wanted them and would even drop them off in my office now and again. But if someone in the office was moving – they had first dibs.
I suspect the local Kinkos has some in the back room for giving away.
By the way on the actual topic of the OP while I have a supply of the Kadee washers (and the thin shims for the entire draft gear box), I also keep a supply handy of the various offfset-head Kadees, both uppers and lowers.
And on this overall topic, I find it strange how often just ONE END of a car needs this help! What’s up with that? Accurail is among the brands where that happens, either direction.
Having said that, sometimes the fault is not the car but an inadequate job by me of making the coupler draft gear box cover tight enough - the sag is my fault.
And I am not too proud to admit that at least one time (OK, OK, a couple of times) the fault was mine in that somehow some 33" wheels “contaminated” the container of 36" wheels. [:$]
I don’t recall the actual measurements in thousandths, but it’s easy enough to lock the setting of the caliper, then place the opening over your scale ruler, as it’s marked-off in increments of 3".
Yes, and exactly why does this happen? One would think that there is some sort of difference in the overall height of the two trucks, but swapping them end for end makes no difference to the affected car end.
