I am about to start on building an ho scale layout and what wondering what advice people have. Thanks!
Nathaniel Nagel
Nathaniel Nagel
The old Model Railroader slogan was Dream, Plan, Build. I can’t think of a better starting point.
Get the various Kalmbach starter books on the subject and read them. Then act accordingly.
Ed
Define what you want and what interests you the most and what is possible in the space you have:
Do you like watching trains loop in circles through scenery? Maybe a classic table or dogbone shaped layout is the best fit for you.
Do you like running trains that imitate the prototype via switching and dropping off cars? Then a shelf style switching layout might be best.
Is there a specific space of real life prototype railroading that tickles your fancy? Design a custom layout to model that real life space the best you can.
Do you have little space available and what some flexibility in the layout? Try building it to follow popular modular styles such as Free-Mo or NMRA standards so you can easily swap in and modules and perhaps join a club to build a bigger layout as a group.
Do you (to quote the late Freddy Mercury) “want it all” with a massive basement sprawling empire with a dozen scenic highlights, countless spurs, hidden staging yards, CTC controlled signalling and LED lights in every building and street lamp? Build a smaller layout first to test the skills you want to take to that basement empire someday in the future.
Get Track Planning for Realistic Operation by John Armstrong. It has all sorts of info that you will need. An around the walls layout will give you more layout than a table in the middle of the room layout. If you do a 4 by 8 table top layout (many start with one) think about a view block down the center of the table to divide the layout into two scenes. You can put a paper photo back drop on the view block, or just painting it sky blue is pretty effective, or if you some artistic talent, a free hand painted backdrop. Think about a big deep river valley somewhere that your main line can cross on mighty bridge. Even if you don’t model the valley and the bridge right away, if you plan for it, the space will be there when you need it. Much of the fun in model railroading is seeing the trains run under their own power. I would push hard to get something running as soon as possible. You can keep working on the layout and add more track, scenery, everything, but getting something to run is a big motivator. I would start off running DC, it’s simplier and you can convert to DCC later if you get into operating with friends. If it turns out to be a sole operator layout there is little need for DCC. Good Luck. Have Fun.
Hi Nathaniel,
Have you looked at the ‘Get Started’ section of this website? It’s in the black strip across the upper part of the main page.
As far as my [2c] goes:
Resist the urge to buy everything that looks good to you, that is unless you have deep pockets and lots of storage space.
Before you start buying rolling stock, learn what is worth spending your money on and what isn’t. A $20.00 locomotive on eBay is not a bargain. It’s a disaster.
It’s your railroad. Run what you want, but…
If you have a 4’ x 8’ space and you want to run Big Boys or 89’ container flats, it just won’t work.
Get a copy of John Armstrong’s ‘Track Planning for Realistic Operation’ (exactly what David Starr is recommending). I designed my original layout without it, and after I read the book I realized that my ‘perfect’ design would have been pretty much disfunctional.
Be realistic about what will work. If you are using pencil and paper to plan your layout get the turnouts and the curves drawn accurately. Better still, get a CAD program. It will prevent you from trying to squeeze things in where they won’t fit. I love 3rd PlanIt but it’s not free. There are free track design programs available.
Go with DCC to start. (Directly the opposite of what David Starr is suggesting). Yes, it costs more than DC but it allows you to focus on running your trains instead of having to constantly keep an eye on track polarity. Sound is neat too if you manage it properly, i.e. turn the volume down. If you go with NCE it is not complicated to get started. Digitrax is IMHO.
Build your grades so that the trains that you want to run can actually get up them. Remember that a grade on a curve increases the pulling power required.
Ask us lots of questions! We are more than willing to help.
Have fun!
Dave
I also recommend this book.
You don’t say, but assuming this is your first layout keep it small and not too complicated. There’s a lot to this hobby that is not readily apparent until you actually build a layout. Don’t glue anything and you can reuse it all on your second layout.
Personally, I started with a 4’x8’ trackplan from Armstrong’s book that was in the first edition (sadly not in the current 3rd edition) that was a basic twice around all one level with a crossing. I learned a lot from it. And since nothing including benchwork or plywood was glued, I was able to reuse all of it including wood for my second 6’x6 1/2’ layout of my own design.
Paul
Start small, take your time and have fun. “Model Railroading is fun!” Do some reading about layouts, track plans, and scenery. Pick a track plan that fits your space and modify it to your liking. Model Railroader is good reading, has something from every topic. Before starting scenery, I recomend making a diorama on a small piece of foam or plywood, and practice different methods before trying it on your layout.
Hello all,
Check out the National Model Railroad Association’s web page.
Under the “Education” tab, there is a “Beginners Guide”.
Hope this helps.
Agree with the Armstrong book. Agree with going with DCC unless it’s going to be a tiny layout.
Pick an era, a region or purpose for your railroad and your purchases.
Do good work. Tracklaying isn’t delicate as eye surgery but you will regret sloppy construction forever. There is no excuse for lumps and bumps, or kinked tracks.
Newbies want everything. The atlas track plan book will show you can have everything in a spaghetti track layout. You can do that, but it won’t look good and you won’t be happy.
You may run across the term switching puzzles, presented as something you have to have. The are unprototypical games, and not a must have.
Yeah I got the same opinion here. There really is no reason in the year 2019 not to start with DCC out of the gate. Simply put, DCC is like the iPhone-Android smart phones of the model railroading world, and DC is like those big brick phones from the late 80’s. Yes, DC does offer some advantages in that its cheaper and somewhat simpler to wire… if you only intend to run one train at a time. However as soon as you want to run multiple trains DC requires wiring with insulated blocks for the yards and sidings, setting up control panels, etc. In comparison, buy an NCE DCC starter kit; make sure there are a few feeder wires to keep all the lines powered and boom; just like that you can run a small fleet of trains altogether in the same power block.
The only analog system that offers a bit more versatility than DCC I would dare say is the AC systems used by Lionel and Marklin, but then you have to accept your track is always going to have a third rail or hidden power feeders in the ties. The AC wiring though is so stupidly easy or non-existant compared to DC or DCC systems its a tempting trade-off for some. For example a wye or reverse loop on a DC/DCC track is a short without the right hard wiring, on an AC three rail system its pretty easy to set up with a few insulating pins. There are also some new systems being tested with radio control and battery powered locomotives but those are so new to the market they aren’t common practice yet so don’t worry about those yet.
Also one note of caution, I have never really read much o
John Armstrong did a lot of designing for small space layouts. As such, 18" curves and switchbacks were often necessary.
In his book Track Planning for Realistic Operation he discusses some of the tradeoffs you have to make. He also covers how railroads did things and some of the ways you duplicate that on your layout. His book Creative Layout Design (sadly out of print) is a good part two to Track Planning for Realistic Operation. These two books are the best at showing John Armstrong’s talents for model railroad layout design. IMHO everyone in the hobby who wants to design their own layout should have these 2 books.
Personally, the only way I can accomplish what I want in my space requires that I use sharp curves and aisleways less than 3’ in most places. But testing of my equipment shows that what I will be running will work just fine for me.
Paul
Is this your first layout? That makes a big difference in what you should be doing.
-Kevin
I think that his use of tight radii is secondary to the value of the information in his book. The book is extremely valuable when it comes to understanding how railways actually work, and it offers modelling opportunities that prototypical operations might not.
For example, my first (uneducated) attempt at designing a yard looked great to me. Then I read Armstrong’s book and I realized that my ‘perfect’ yard design would not have worked well at all. In fact, it would have been quite disfunctional.
As far as his use of switchbacks at industries, I think that one has to recognise the operating interest that such track arrangements provide. Whether or not they are prototypical of modern operations isn’t really the point. The switchbacks give the operator something to do besides simply running trains in and out of a siding. On our club’s new permanent layout we are deliberately adding in non-prototypical track arrangements in some of our industrial sidings simply because they will provide an opportunity for an operator to move cars about for a couple of hours without going on to the mainline. Prototypical railways would do anything to avoid unnecessary car movements. We chose to do exactly the opposite.
The book is well worth reading. You will get an enormous amount of useful information from it.
Dave
I am fairly certain that my comment might meet with some resistance, but I would suggest starting off with a simple 8’ X 4’ layout with a starter DCC system. A couple or three spurs and a siding and you can get some expereince running a train, switching industries and figuring out what you want in a larger layout if it comes to that. Beyond Armstrong’s book, MRR mag has a lot of great 8’ X 4’ layout plans in the data base.
With the tons of legitimate good advice given in the answers, I am afraid we have either intimidated the OP or he just poked a stick into the anthill to see how we frantically move around.
With 13 posts so far, the OP is not under moderation and could have shown up and give a feedback.
Heck, he just started this thread on Saturday. Maybe he works for a living and cannot reply during the week.
But, the real issue is the opening salvo, “I am about to start on building an ho scale layout and what wondering what advice people have”.
The question is so broad as to defy any real substantive answers. So what is there to reply to?
I’m busy a lot and I work for a living but it’s easy to reply to a topic these days what with computers at home, at work and smart phones in the pocket. I agree with Ulrich, the OP could drop by and help us better help him sooner than later. So maybe he can’t drop by the forums on his lunch break at work, what about home? What about while visiting the loo and post on the smart phone? [:-^][(-D] Where there is a will, there is a way. Truth!
Yes, often people come in and need to throw us a bone to get better help.
Resistance is futile!
For a beginner, I totally agree. Lacking any information, start with a 4x8 and use that platform to build the basic skills of building a layout. Then you can think about leveling up to a larger layout after that.
I don’t think it makes sence to write a treatise for the OP until he fills us in on some specifics.
There are a lot of factors to consider in this hobby. MR is something that provides a lot of enjoyment with building new things, recreating a part of a childhood, or trying new skills.
Perhaps the OP wants to see this post “grow a bit” before providing more detail. We’ve provided a lot of sound advice. The suggestions here require serious consideration. I get that this hobby requires a level of dedication. I too have a family and a full-time job. Devoting hours to it daily are not possible. Heck, even giving 45 minutes at night is not always possible.
There is a dizzying amount of information on this hobby online. Something unmentioned is talking to a local LHS or NMRA group. Perhaps the OP can find a mentor who can steer the OP through some of what’s above.
Keep a record of what you did each day during the construction of your layout. I did this just because I am curious to see how long the railroad took to build.
