airbrushing
I am considering an air brush with some of my Christmas $$. I often see pictures of track being airbrushed. Can this be done in an open room - not under a hood? My layout is in my basement, limited ventilation. I am new to airbrushing and recommendations for types would also be appreciated. Thanks for the input.
I do all of my airbrushing in our basement. I normally open a window or on a nicer day the basement door. I don’t really have a problem with the fumes. I guess if you have enough venting you should be fine until you can get a hood. I don’t have any plans for a hoodvent anytime soon. I feel like I don’t need one for what I do. I am sure some people use them if they use it alot.
You will get alot of answers with the qustion of which airbrush is better. Single or duel. I use a duel airbrush. I think it works better. I got my airbrush off of AIR BRUSH CITY web site. I think it does real good.
If your new to airbrushing then you might want to start with a single action airbrush. It’s easier to control the amount of paint that will flow out of the airbrush, however it does not let you control the amount of air that comes out of the airbrush. After you feel comfortable then I would really recommend a dual action from Iwata. They are one of the best companies to make an airbrush. Now when it comes to paint, use water based paints. It better for your perconal health. The acrylic which is what I find actually works better but are not as good for your health. When using acrylic you should have some sort of mask do to the amount of particles from the overspray that would be airborn. hope this helps
As long as your paint is water soluble there will be no problems.
