Alco Switcher Locomotive Without Short Nose
I was at a club I’m planning to join this evening and a guy I was talking to said that there is an Alco (I want to say RS3 but I’m not sure) down in New Orleans that had its short nose removed because it was in switcher service. Any help?
Your question has me wondering, what is under the short hood on and RS3 or a GP7?
thedieselshop.us shows a RS1 rebuilt as a “cowl” for passenger service on Alaska RR. It looks a lot like a F3. None of those are said to survive. It could also be how they repaired crash damage on that particular loco.
The toilet.
Steam generator on locos so equipped.
And the sandbox for the short hood truck, the head lights for the short hood end, dynamic brakes if so equipped, miscellaneous control equipment (cab signals, radios, etc.)
Is it really an RS with the short hood removed, or just an S model which never had them? Depending on the model, the long hoods can be very similar.
Google search “Penn Central 9950” and/or “Conrail 9950”
Interesting! Kind of the reverse of C&NW’s “Hammerhead” Alcos:
http://www.rrpicturearchives.net/showPicture.aspx?id=2389375
Speaking of no noses…
I have a dog with no nose.
How does he smell?
Awful!
(For the Monty Python fans) [(-D]
No, they were located near the center of the long hood.
Ed
I have led a sheltered life, and never seen such a thing.
I LIKE IT!
But where do they put the top of the gearbox for the “rear” truck?
Ed
Don’t be silly — isn’t it obvious it has tank drive?
PC 9950 is like what I was looking for he said there was huge porch on it. Now someone mentioned a geep 7 without its short hood you have to post a picture of that!
You might be talking about this one:
http://www.rrpicturearchives.net/showPicture.aspx?id=345929
It’s a GP9.
One our younger members built one, IIRC.
Mike.
That’s just wrong, shame on them.
Don’t forget Hobbytown!
Ed
Dynamic brakes on equipped RS3 were on top of short hood, GP7 on the long hood.
Ed: your correction needs correction. You are right, if it is a GP7, but the original poster mentioned RS-3s (even if that may have been a misidentification). If equipped with dynamic brakes they were located in the short hood, and that was the case for all the low hood Alco roadswitchers.
Once Alco changed to the high hood models (RS-11 and following), then there was room under the long hood for the dynamic brake. Even so, CN still ordered some of their RS-18s with the d/b in the short hood.
John
Nope. In an RS2, 3, RSD4, 5 the dynamic brakes were located in the short hood, they had intakes on the sides of the hood and exhaust out the top. The louvers on the side of D&H 4123 are the intakes and the exhaust is the square thing above the number boards.
That’s why the “hammerhead” RS3’s that had both a steam generator and dynamic brackes had a full height short hood, because both had to fit in the short hood. WM 193 had both, notice the rectangular exhaust for the DB on the top of the short hood.
Baldwin roadswitchers also had the dynamic brakes in the short hood.
Yikes. You mean I was WRONG?
OK.
I thought that DB’s on the RS-3 were indicated by those long slot thingys that are on the long hood between the lift-up doors on the edges of the hood:
I suppose they may have been general ventilation, though. Or something else.
Ed
