Alleghenies
The C&O is derided for buying the 2-6-6-6 Allegheny because it’s power/speed profile didn’t match the service that the C&) used them in. Yet, the Virginian bought copies and no one ever talks about them. Is there something we’re missing here because both RRs were competently run and had good mechanical departments?
The same criticism has been directed towards the Virginian’s close copies here and there in the pages of Kalmbach publications. For instance here’s what Neil Carlson wrote about them in his article ‘Fast Freight Articulateds’ for the 2004 Steam Glory special issue.
“In 1945 the third Pocahontas coal road, the Virginian Railway, also received eight Alleghenys to replace 2-8-8-2 and 2-10-10-2 Mallets on coal drags between Roanoke and Norfolk. As with C&O, this was not exactly the service for which the locomotives were best suited.”
He argued in favor of 2-8-8-4’s for roads like this one, the C&O, and the D&H instead of the types of fast freight articulateds that they went with for heavy service on mountainous lines where they rarely could put their power potential to full use. Presumably something like a modernized NP Z-5 or the modern M-3’s and M-4’s on DM&IR.
I believe author Ed King, a familiar name to Trains readers, has also been criticial of the choice of these by C&O (and at the Virginian by an executive right off the C&O where he had been impressed by their new Alleghenys) in the pages of Trains several times through the years.
All the authors can make all the claims they want. C&O found the engines met their needs - that is all the is necessary.
My impression is that the H-8 was like a Class A on 'roids. Both were meant for higher speeds, but except for troop trains (and I have never seen where those trains moved faster than many/most freights…to be honest), and maybe an express freight or six, the H-8 was often under-utilized.
They did indeed do some fast freight.
https://www.trains.com/trn/railroads/locomotives/locomotive-profile-2-6-6-6-allegheny-type-steam-locomotive/
I don’t think anyone has ever questioned that.
What we’re missing is knowledge. In many cases, we’re missing common sense.
The knowledge we’re missing is what it cost to pull coal up 0.57% with a 2-6+6-6 instead of with a 2-8+8-4 or compound 2-8+8-2. Railfans figure since the 16-driver engine can pull more, it must be cheaper to operate. Apparently C&O didn’t think so – so, what do the fans know that C&O didn’t?
No fan has ever had an answer to that question, and no fan ever will. For all we know C&O would have done better pulling coal to Alleghany with compound 2-10+10-2s, but for one reason or another they didn’t think so.
Here on Trains people have theorised that C&O was determined to have the world’s most powerful steam locomotive, so they ordered 2-6+6-6s knowing they weren’t the best choice for their coal trains. So they ordered ten of them, and got the 6700 dbhp or whatever it was. So now they have the record – what now? Now they’re free to buy the right engine for hauling coal to Alleghany, while they use the 2-6+6-6s on coal trains west from Russell. Instead they bought more 2-6+6-6s.
And if C&O was only concerned about showing the world they had the biggest engine, why did they keep quiet about it? Pretty sure there was no mention of the “7498 dbhp” in Railway Age, Railway Mechanical Engineer or even in the C&O company magazine. No mention in Trains until the 1950s – probably no mention in Railroad?
Did Virginian regularly use 2-10+10-2s east of Roanoke? Or even 2-8+8-2s?
In any case, no reason to assume a 16- or 20-driver engine was the best choice for coal up the Virginian’s 0.2% grades east of Roanoke. (I forget – did VGN have a 0.6% climb east of Roanoke?)
A clue might be the year: 1945. During WW2 the War Production Board and other federal agencies determined what was built and with what materials. It was not unusual for railroads to order a run of a particular locomotive, only to be told they had to settle for something else. Maybe the Virginian engines were all they were able to get at that time?
For example, I recently purchased an HO (Athearn Genesis) model of a Clinchfield 4-6-6-4 Challenger. The booklet that came with it explained that during the war, the Clinchfield and D&RGW had tried to order large engines of different designs, but instead were told their order would be added to UP’s order for more Challengers.
Many railroads who ordered EMD FTs were given steam locomotives instead…except, oddly enough, Minneapolis & St. Louis, who ordered 2-6-6-2 Mallets and were given FTs instead. The railroad would have had to buy steel to upgrade several bridges to handle the heavier steam engines, and Washington decided it would take more steel to do that than to give the railroad lighter but equally powerful sets of diesels.
The VGN’s steepest grade eastbound was .33% for one mile at Board Mountain, just east of Goodview, Va. Heading west toward Board Mountain the grade was .62% for three miles.
In my opinion the Allegheny design was the ‘next step up’ from a T-class 2-10-4, and since most of the ‘overweight’ was in the complicated system that allowed free high-speed running of the locomotives, it is pretty clear that C&O wanted big locomotives that weren’t limited to drag service at drag speeds.
It might be added that it’s at least possible that C&O saw wartime fast heavy manifest traffic ‘coming’. As on the PRR, where there wasn’t much advantage of a Q2 over a T-class clone on a 50mph railroad, but a very clear one for 150-car trains at war expedient speed, C&O might have wanted a more ‘multipurpose’ engine than a more “appropriate” 2-8-8-4 double Kanawha. I defer here to authors like timz who have access to sources in the literature that discuss this.
Something I find interesting is the decision to build large and untried steam turbines (on Baldwin’s word that they understood these things better than Carleton Steins!) for their Cincinnati superstreamliner instead of doing what N&W did – I think for the same actual reason – by putting lightweight Timken roller rods on the last class A 2-6-6-4s. Certainly Chessie was no stranger to these: 614 famously had them in 1948.
Whether or not C&O ‘found a place’ to use the engines expediently after 1945, they were fundamentally ill-suited to the use C&O appears to have generally put them to. What I find surprising is that there appears to have been no effort to modify the Alleghenies with smaller drivers (which by that time would not have implied lower achievable road-speed balance and augment characteristics) in order to bring the horsepower peak – which, remember, was fixed by the water rate rather than anything involving the driver adhesion – to be achieved at typical coal-train speed.
I think you s
Going in the other direction, why did C&O buy 10 (down from 25) H-6’s when dieselization was well under way?
I have often wondered that, butbI think I know the answer. Price and availability. I bet they were cheaper and could be delivered sooner. And the crews knew and liked the earlier versions.
Other roads brought steam out of mothballs several times because the diesel builders could not deliver fast enough.
Just a thought I had about this years ago,
Sheldon
Like a handful of other bigger roads, the C&O famously resisted the diesel well after most Class 1’s had decided it was the future and that dieselization in an as fast as economically possible manner was the path forward.
They made a lot of money hauling coal, it was cheap to burn in their fireboxes, and they didn’t want to upset coal interests that also were their customers. And I don’t know if it’s the case, but I also wouldn’t be surprised if they had a company owned mine to supply their coal, adding to the appeal of continuing to burn it as a fuel.
These articulateds for mine runs, just like their other late 1940’s orders for 2-6-6-6’s, 2-8-4’s, 4-6-4’s, 4-8-4’s, and the 0-8-0’s that ended up being sold to N&W in short order around 1950 or so when they were just a year or two old, these and the three steam turbine electrics were all produced before that shift had happened in C&O’s management. Heck, even the brand new Spartan and Badger burned coal in their boilers when they were launched in the early 1950’s.
Hopefully my recollections are accurate, but as I recall the gist of how such a sudden change came to be was due to the coal miner strikes happening at the end of the 1940’s. Due to the uncertainty and rising cost of locomotive coal, the C&O bought some road diesels instead of new steam power in 1950 (F7’s and GP7’s, iirc). They liked the results so much with EMD’s latest road power that they changed course almost immediately.
Too bad you weren’t around to tell them. “Fundamentally ill-suited … golly! You’re right! Thanks for straightening us out.”
Somehow I feature R.R. Young would not have listened to that criticism.
If a different design could haul more tonnage both faster and cheaper on the runs that the C&O assigned them to, I don’t find that unfair. Steam experts in the railfan hobby have often talked about how they were miscast, such as Robert Le Massena.
I don’t think anyone would want to change history. They were beautiful, powerful, and efficient machines. I think railfans and likely those that worked on them were both glad that they existed. The C&O naturally was proud of the class, as evidenced by them saving two examples for posterity.
Pointing out that they rarely got a chance to take full advantage of their capabilities isn’t a slur. But math and physics don’t lie and the design wasn’t as tailored for the duties it found itself in (coal drags or working heavy trains in the mountains) as some others would’ve been.
A good example of this were Western Maryland’s modern Challengers. Their modernized and much older 2-10-0’s ended up being used on the same assignments, able to get similar tonnage over the same grades in a similar amount of time.
The Challenger’s performance advantages were largely nullified by the assignments and territory it operated in, although its modern design presumably yielded a significant savings on coal and water compared to the 2-10-0’s. Yet at higher speeds their Challengers obviously could’ve ran circles around the much older 2-10-0’s.
From books I have read about the WM, the Challengers could not outrun their financial hit on the WM finances. It is my understanding the locomotives were mothballed two years before their financial commitments ended. WM could afford to operate the locomotives or pay for them - but not both.
Too bad I wasn’t around for the M-1s either; I could have told 'em why those would be ill-suited, too.
It’s not rocket science to figure that a locomotive routinely operated over 20mph below its peak horsepower range is losing money; it’s not rocket science that the additional cost to build a locomotive to have its horsepower peak at high speed is a comparatively poor capital investment.
C&O was the railroad that couldn’t figure out that loading a PRR T1 with two extra cars because of its nominal horsepower rating wouldn’t cause a short-stroke engine to stall – or is there something wrong with Dave Stephenson or me pointing out how that’s wack?
