American freight trains-59 mph....German Freight Trains-80mph The FRA is FAXing US railroads over.
Was talking to a german rail fan at a yard in ohio today. He told me that german freight trains do 80 MPH (But passenger trains get priority). The FRA is hancapping freight railroads by limiting there speed if we have faster freight we could have faster passenger. In Canada i was told 90 MPH freights were not that uncommon and this was before CTC.
I don’t think Canada’s freight could do it unless they started using a large consist of P-42s or F40PHs. I don’t think engines for freight service can go beyond 70 or 75mph.
Think that is the point - we have to start thinking in terms of faster freight trains - we have to plan for 90mph plus freight now - especially with increasing intermodal traffic . In Canada we have long sections of fairly straight track (except in the west) Now is the time to upgrade to faster track like the Europeans .
How heavy are these trains that they can achieve such high speeds
Do the Germans run 16000 ton coal trains at 80MPH? I doubt it.
If we had a government owned, nationalized primarily passenger railroad with some relatively small and light freight trains, we too would probably run 80mph freight trains.
Even when the railroads had 90mph passenger train speeds, most freight trains ran normally in the 40 to 50 mph range.
Jeff
In European countries and in Japan, the lines are electric and so most of thease high-speed freight is electric. You have to keep in mind that thease countries are far smaller than ours and so to electrify our countries would be quite expensive. Some of the existing lines such as the North East Corridor is a start but it will be difficult for the railroads to contiplate undertaking such feat of investment unless the government does some big time investing. I think it will happen sooner or later but for now, trying to get the U.S government in particular to spend alot of money that will benifit the transportation infrustructure and not on frivilous things like missle defence system to protect against non existant ememies who are at peace with you. Lets face it, when it comes to the rails, congress can barely find the interest to fund amtrak never mind something this big; and the Canadian government is no better. If this is to happen we will need to vote in governments who are interested in doing this and we of course as voters of our respected countries, must support the party that will do this other wise the railroads are quite content on using diesels that they have already spent a fortune on.
It it quite simply unsafe to operate most existing American freight trains at speeds above 80mph without properly-designed automatic train control. (The current acronym is “positive train control”, in part intended like the term “MRI” to get around some unpopular connotations that the old ‘ATC’ has acquired).
The current tests of PTC, in particular the ongoing NAJPTC trials, may produce something suitable for use on freight trains (a very, very different, and more difficult, engineering exercise than PTC on passenger trains). Until then you can expect a hard speed limit below 80mph (as in the current law). I wouldn’t sit around waiting for locomotive manufacturers to start designing engines geared for higher freight speeds before then – regardless of the extent to which they might do that afterward.
I remember that some of the UPS high-speed trials had to be run with borrowed Amtrak Genesis power a few years ago, nothing else around being particularly suitable. I believe it’s possible to adapt modern six-axle locomotives to run at higher speeds, particularly those with AC drive… but until there’s a hard business case to do that, and equally well-documented system solutions to make that business case profitable, there’s no particular point in bandying about proposals to run freight trains at superspeed.
Note that Amtrak could run 100+mph freight in the Corridor (and elsewhere) fairly quickly if that were desirable… either with RoadRailers or with appropriately-suspended ‘material’ cars. There is little difference between many of the old NEC mail trains and a freight train, technologically speaking (although there may be worlds of difference in maintenance quality and detail design of actual equipment)
The issue is entirely about first inducing and then satisfying demand for service that uses those speeds. Service that pays for them.
There are at least three things involved, money, money and money, and possibly a fourth- no money.
Higher speed trains require more horse power on the point-more locomotievs.
Higher speeds increase the gallons per mile consumed for a train.
Higher speeds generally require tighter tolerances for track.
The fourth item. Faster train speeds don’t necessarily equate to a reduction in door to door transit time, or at least a reduction in time that is worth any more money than is being paid for service at existing levels.
Dealing with trains operating at different speeds is a well defined problem. I suspect that the conventional solution of adding passing sidings or double tracking with CTC is quite a bit less expensive than running freight trains faster to keep them out of the way of the occasional passenger.
There are quite a few places where you can run a freight train at 79 MPH…railroads cannot get an acceptable rate of return to justify the extra expense in fuel and maintenance on railcars…Doesn’t pay? - Don’t do it!
What about the time element – ie A to B at least 10mph faster say with an intermodal – doesnt this translate into more dollars if you can get it there quicker! – especially with so many Asia - Europe land bridge trains .
Leave it to the Germans to brag AGAIN about their superiour transportation system, but do they have ove 100000 ton freights on a regular baisis? America is probably slower because we produce much more heavy raw materials
What was this intermodal bridge I heard CN was supposed to get out of buying BC Rail and building a new port possibly?
You forgot North Korea. Also, most people did not expect what happened on September 11, 2001 to happen, maybe they should have but they didn’t.
North Korea will not doing anything because China won’t let them and neither will the Russians. Long before the North Koreans could lauch anything anyways, an interceptor fighter from Okinawa could be scrambled to destroy the missile. Like I said, it is inconsievable that China would allow such an attack because any nuclear attack against the U.S would be met with nuclear retaliation and China is too close to North Korea. Why do you think the Soviet Union didn’t attack with those weapons? September 11th was carried out by a group of religious fanatics without a country to loose. The only reason why the Taliban doubted the U.S resolve was because they were part of the same Clique. North Korea has an organized government that is interested in its image and is to the degree under China’s thumb. China won’t do anything unless seriously provoked because they don’t like war because they are more interested in fixing their land and perfecting it. China knows that the best way to attack the U.S is engage it through Commerce hence why alot of jobs are going to China-Made in China and now that they have Hong Kong which was left generally non-communist, they are very serious in growing their economy. The age of possible World War is dying and I would say that only the middle eastern countries not allied with the U.S would be a threat. I would say right now the real threat will be Iran since they are the ones developing nukes and is ruled by a religious leader-Iatola, which is openly aggressive against the U.S
The port is Prince Rupert in northen BC - CN can pick up containers there and run them to Chicago , apparently it is closer by a day than the lower BC and US ports . The port has to be upgraded so this is an ongoing thing .
It get’s back to the old idea a decade ago (I’m not sure if it was part of the failed SP-SF merger, or an outgrowth of the UP-SP merger) that if a RR has two separate (redundant) mainlines from point A to point B, that you primp one for the lighter higher speed intermodal/time freight traffic and buttress the other for the slower heavy drag freights/unit trains. It was something like making the Sunset Route the faster route and the Overland Route the slower line. It makes sense to do it this way rather than running both kinds of freight on both lines because you can then do things like superelevating the curves on the faster line to increase train speed.
I think there are a number of redundant lines in the U.S. in which this philosophy can be implemented. You run the 10,000 to 15,000 ton coal and grain trains over one line and the 3,000 ton intermodals over the other, that way the higher speeds on the latter do not exasterbate track maintenance since the average tons per axle are much lower. In other words, it can be done if the business exists to justify the effort.
Remember the Santa Fe used to run freights really fast in the west back in the 40’s…but if it doesn’t pay to run these drag freights at higher speeds than the status quo, railroads won’t do it.
Course, US Passenger trains used to do pretty good time too, but that’s a subject in itself…
I agree that North Korea probably will not attack. However, it is possible. Also, there is no way to make sure that Iran never gets ICBMs. I would rather have a missle defense ready for them in case they are bought or developed rather than trying to develop one then. Finally, world politics is not a static thing. What is the case now probably will not be in ‘x’ number of years.
Were there land-bridge trains until recently? I distinctly recall reading in a rail publication that there were some trains in this service a few years ago. One of the issues the article discussed was the limited ability of US railroads to increase capacity. There was discussion of enlarging Panama Canal to allow larger container ships and therefore bypass the US rail routes.
I have not heard any more on this [expanding the canal] beyond that one article, so it could have been written off as “not feasible/too expensive”
I can’t resist it anymore. Where is the FRA faxing railroads to? My apologies, but I couldn’t resist.
