I need to measure the stall current on my DC locos before I choose DCC decoders to install. I’m looking for the recommendation of a few, relatively inexpensive meters. There are so many to be found on Amazon or Harbor Freight, can you please be specific as to model names/numbers? Thanks!
NNJ,
I picked up a nice digitral multimeter at Sears several years ago for $20. It comes with two probes and even a thermocoupler for measuring temperature.
Craftsman? Something like this (but no thermocoupler)?
This is what I have: Craftsman 82400 digital auto-ranging multimeter
It may be a discontinued item now. Like I said, I bought several years ago.
My kid bought one of these off eBay
http://www.ebay.com/itm/151705209431?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
He says it works very good. I have a sack full of the Harbor Freight Free Bee meters that work great.
Mel
My Model Railroad
I have a couple of multi-meters but for (like you) testing DC locos before DCC conversion, I put a 3’ flextrack (even made s-curves in it) on a plywood strip. I included a 2A analog meter, which was cheap, arrived fairly quickly (probably within 2 weeks) and is accurate enough to see if a loco is a special case regarding decoder selection.
How do you connect it?
I have used the HF meters for some years. I have four. Cheap enough.
http://www.trainelectronics.com/Meter_Workshop/index.htm
The linl below shows very clearly how to do a votage amps check for a loco. Yes, you can do it with one meter but these meters are cheap enough.
http://www.trainelectronics.com/Meter_HF/index.htm
The meters measure 13.6 vac on my NCE Power Cab. Agrees with my digital Scope.
As a DCC amp meter, use the ZXCT circuit below on the 20ma scale. I bult two. One for me and one for club some years ago.
http://home.cogeco.ca/~rpaisley4/DCCvolts.html
See the two large bolts on the back? In series with the power to the test track, just like you’d connect a multimeter. Can’t run backwards though with that type of meter, unless you get fancy. Can’t with a multimeter either, unless you swap the leads. There are similar meters that are center 0, so they can indicate for either polarity.
I have half a dozen Harbor Freight meters that were free. All give slightly different readings, but I just average them out. [:-^]
That works just fine. I have done that over the years. This is model railroading, not rocket science.
