Well,
I guess I’m different. I use wireless radio DC throttles - Aristo Craft Train Engineer - to be exact.
So no decoders/receivers in locos.
To direct power to the trains, I don’t use toggles or rotary switches, but rather pushbuttons and relays.
Using a modified version of Ed Ravenscroft’s MZL control. This provides for walk around and central dispatch panel operations, detection, signaling, collision avoidance and allows for very simple user interface.
Many “blocks” (we prefer the term “electrical section”) are automaticly assigned to the correct throttle (or turned off compleltey) by turnout positions, and the number of “cab assignments” that need to be made is minimal. In CTC central panel mode, the dispatcher assigns the routes and cabs leaving the engineer to only run his train.
In walk around mode, pushbutton stations are proviided around the layout where ever needed to allow proper assignment and local tower panels are used to set turnout routes which automaticly assign track power as well.
My turnout controls are intergrated into the system providing one button selection of complex routes through yards and interlockings and making it impossible to throw a “switch” under a train.
My system is niether simple or inexpensive, but if you want signaling and CTC, it costs way less than getting similar features with DCC, especially if you have a large roster/layout.
It is not friendly to onboard sound, but I don’t want/like onboard sound in HO.
The Train Engineer throttles provide great slow speed and constant lighting and are very easy to use.
For the layout goals I have, I would not use anything else.
There are three or four other well known regulars on here using DC who have not commented in
