Aristo's nwe RDC-3
The new RDC-3 is a good looker!
I think it was worth the waite.
So I’ve had time to run this unit around the layout.
Well you will find all you track problems!!
I was told the sd-45 has some of the same track quircks.
Well we got the track tooned up.
Runs well.
No for the seats inside ! HHMMMMMMMM.
I’m glad I do not have to sit in them!
I plan on putting some people inside.
Any thoughts on an engineer or conductor to place @ the throutle ?
I was thinging some clown!!
Check out some pics : http://www.aristocraft.com/vbulletinforums/showthread.php?p=157291#post157291
Sean
Did you fall into the cooler before you worte your post or what???
Dave
Same problem as your’e worte. David
Thanks I think I fixed it.
Howdy Sean; I had similar problems with my RDC1, or should I say track work problems. Mine has a stiff suspension; track must be level side to side and what an overhang on each end.
Have fun, Rob
