Athearn Challenger Tender Shell Removal
Has anybody taken the shell off the tender. I can’t see any screws and pulling the sides out doesn’t do it. Help please.
I did this a few weeks ago.
Look behind the coal bunker, you will see a little tool box. Lift UP the tool box and this will allow the coal (or oil) bunker top to slide back and up. It will expose 1 of 2 screws that you will need to remove in order to remove the shell(it exposes 2 screws, but the little one is not nessesary). The second screw is under the middle water hatch. Just pull UP on the hatch to expose the screw. The rest of the screws are underneath the tender body.
Let me know if this helps.
David B
Thank you, thank you, problem solved. Bill
Any time…
…now while you are in there, rip out that horrible sound decoder and install Tsunami Goodness…
David B
Amen! I did that and I’m very pleased with the results. I even replaced the orange headlight for a warm white LED as well as crystal marker lights. WoW is all I can say!!
