Athearn Genesis F3 DCC Ready - Choosing the Right Decoder
I bought a pair of DCC Ready Athearn Genesis F3AB locomotives. I am a bt confused about selecting the right non-sound decoder for each locomotive.
Here are the instructions from Athearn.
Here are photos of the “DCC Jumper Board” still in place in the first photo and removed in the second photo. As you can see, the circuit board has a 21-pin configuration.
So, the Athearn instructions say to “plug in a decoder with either a 9-pin plug or an 8-pin plug”. But, the circuit board has that 21-pin configuration in place.
Can someone help me sort this out?
Looks like a 21-pin to me, Rich. You could always call or email Athearn to verify and let them know of the error on the instruction sheet.
Thanks, Tom, I will do that. I wonder if the instructions are from an earlier run, although these locos have LED lighting which is a welcome change from those crappy incandescent bulbs.
So, do I need a decoder with a 21-pin connector? I assume that is the case.
I have an Athearn Genesis F3A-B that was given me by Ed and it came with an 8- or 9-pin socket. Yours has to be a newer run.
Yea, from the photo you’re going to need a 21-pin decoder, Rich. I would go either TCS or LokPilot for a motor-only install. I used a TCS A4X in my B-unit and a TCS WOW WDK-ATH in the A. They run very well and smoothly.
Rich.
It looks like Athearn upgraded the motherboard but not the instructions. They did the same thing going from the 8 pin to the 9 pin JST.
When I was doing installs for club members, one guy gave me a pair of locomotives and two 8 pin decoders for them. Upon opening them up one was 8 pin the other was 9 JST. Both bought at the same time. Kind of like a box of chocolate. You never know what you’ll get.
Pete.
Rich.
Looking at the motherboard, it appears to be mounted backwards. The FO is on the opposite side of the cab. There is also solder pads for a speaker. Very easy to add sound if you want.
Pete.
A Nix Decoder Buddy circuit board may allow you to adapt a 21 pin to a 9 pin.
A decoder buddy is not necessary. A decoder buddy is used for converting older 8 or 9 pin locomotives to a 21 pin decoder. It has solder pads for accessory lighting, speaker, and some have a keep alive solder pads. Their latest board has a socket with lighting solder pads to allow complete shell removal. (Nice feature). The mini works great for locomotives without a lot of room. I have it on good authority that an even smaller version that uses the Next 18 nano decoders in the works.
Pete.
Here is what still confuses me. In the past when I have converted a DCC Ready loco to DCC and the factory installed circuit board has an 8-pin plug, the plug itself has 8-pins (male) and the circuit board has an 8-pin receptor (female). So, the plug is removed and a harness from the decoder has an 8-pin connector (male).
But, in this instance, the circuit board has a 21-pin receptor (male), and the plug has a 21-pin connector (female). So, when I remove the 21-pin plug to install a decoder, I will need a 21-pin connector (female). How do I deal with this? What decoder would I use? Would I need a special harness?
Rich.
The Athearn motherboard has a black plastic cover over the pins. Carefully work it up from end to end. It’s there to keep the pins from getting bent. Then match up the decoder and press firmly.
Any 21 pin decoder will work.
Pete
Rich.
I’m sorry. Looking at the second photo again I can clearly see the bare pins so there is no cover. Notice the one missing pin? The decoder socket will have a blank spot where that missing pin should be.
Pete.
For all of my Genesis F units I have used either the Soundtraxx ECO PNP for the older boards or the Soundtraxx ECO-21PNEM. In your case the ECO-21PNEM would be a good plug in if you want sound. If not any 21 pin, like the Soundtraxx MC1H104P21 or any of the ESU 21 pin Lokpilots. The Soundtraxx is much cheaper though.
Good news with that board if it is a newer version with LEDS you don’t need to worry about blowing bulbs and they are much easier to add decoders to.
The big issue I have had in adding sound to these Units is what to do about a speaker. While there is a lot of room back there the speakers on the market tend to be to big or to small to fit right. I have used and like the Scale Sound Systems speakers made to custom fit this space. They sound amazing as well. There are several You Tube videos comparing these.
SB
No worries, Pete. Your ealier post prompted me to go take a closer look at that circuit board setup. As I looked closely, it seemed that there was no way that 21-pin receptor on the circuit board could be a black plastic cover over the pins. So, your latest post confirms that fact.
I’ve installed a couple of the SSS speakers in a pair of brass locomotives and agree that they sound terrific. I really appreciate all of the time & effort JT has put into optimizing the 3D printed baffles with the speakers.
Thanks for that infor, blabride.
The Soundtraxx MC1H104P21 looks like the decoder that I am looking for. So, that connector is a female connector that will fit over the (male) pins on the motherboard?
Before I read your post, I was considering the Digitrax DH126MT decoder. I assume that decoder would work as well.
+2 on the Scale Sound Systems speakers. I put my first pair in an Athearn Genesis F3 A & B and was convinced these were the best sound improvement money could buy! I’ve replaced over two-dozen former supposedly “deep bass” speakers now with the SSS units.
Rich, read the instructions carefully when you do settle on a 21 pin decoder. Some install with the pins passing THROUGH the board then into the socket. This seems contrary to logic but it is the way they’re designed.
See page 26 here:
https://soundtraxx.com/content/Reference/Manuals/Tsunami2/Installation-Guide.pdf
I know some of my Soundtraxx and TCS motherboard/decoder combos were this way.
Good Luck, Ed
Ed, I’m not sure that I follow you. What do you mean by “through the board into the socket”?
For an 8-pin connection, generally the ‘female’ receptacle is built into the lightboard, and the decoder (or it’s harness) has the ‘male’ eight pins. 21-pin connections are the opposite, the pins are in the lightboard and the decoder has the holes that the pins go in to.
Unfortunately I can’t see the OP’s pic, but note that some engines made in recent years have options to plug in a 21-pin decoder and an 8-9 pin decoder too.
Note that the OP is asking about a non-sound decoder…
When I got my first 21 pin decoder some years back I studied the newfangled thing for quite a while. My inital “assumption” was to place the black socket on the decoder facing the pins the way any ordinary plug and socket combination would seemingly work.
After studying the situation and the documentation for a while it suddenly dawned on me that the decoder had to be placed onto the “motherboard” with the PC board in the same orientation. In other words the gold pins passed through the bottom of the decoder then engaged the black plastic plug which is now oriented on the top side or facing up.
See the Soundtraxx guide I linked to above, Pg. 26.
Of course the index pin will help answer alignment issues but it had me scratching my head for a while. IIRC, the TCS decoder had a little piece of Kapton tape over the “NO” side of the plug.
DCC documentation from nearly ALL the major decoder manufacturers is awful, at best. Dave (HOn3 Critter) had a keep alive diagram that had the + and — pads reversed. Soundtraxx confessed that, yes, maybe some were shipped with the wrong hookup drawings but, well, sorry.
Good Luck, Ed
Rich.
There are two rows of pins. In the second photo you can see a pin missing on the left corner nearest the cab. The decoder will have a blanked out socket in the missing pins location. Look at the 21 pin jumper board removed and you should see what I mean. Actually the decoder will mount in the same orientation and location as the jumper plug.
Have you considered a TCS decoder? Really excellent motor control. A Locpilot would be nice too. It has the automatic BEMF adjustment that gets good results.
Pete.
