Athearn Genesis GP7 constant on. How do I turn that feature off?
Hi all I have a new Athearn Genesis GP7. It is set from teh factory to have the sound come on whenever the decoder gets power. Annoying [:(!]. Hoe do I change the decoder so that sound comes on either with F8 or wit’s speed step 1?
Since it is probably a Tsunami sound decoder, you will need to adjsut CV114. This value affects the prime move notching as well so be careful. This is from the Tsunami 2 manual.
CV 114: Adjust Auto-Notching Sensitivity Add a value from 1 to 15 to CV 114 to adjust the number of speed steps within each engine RPM notch from 1 to 15. Auto-notching is set to 7 by default, but we recommend a value of 15 when DDE is enabled. You may use the RPM+ (F5 by default) and RPM- (F6 by default) functions to manually adjust the engine RPM notch level during operation when auto-notching is enabled.
CV 114: Enable Manual Notching Set the auto-notching sensitivity level to 0 to enable manual notching and disable auto-notching. When manual notching is enabled, the engine RPM notch level will not be automatically adjusted in response to the throttle setting, and you must use the RPM+ and RPM- functions to adjust the engine RPM notch level during operation. Manual notching is intended for simulating the prototypical operation of a diesel locomotive and allows you to change the engine RPM notch level when most appropriate. Manual notching is disabled by default.
CV 114: Enable Engine Interlock Add a value of 16 to CV 114 to enable engine interlock. When engine interlock is enabled, you must turn on the RPM+ function to start the prime mover before setting the locomotive into motion. Similarly, you will be unable to turn off the prime mover during movement. In other words, the locomotive must be stopped before you start or shut down the prime mover. Engine interlock is disabled by default.
CV 114: Enable Auto-Start Add a value of 32 to CV 114 to allow the prime mover to start when the decoder receives track power. For DCC operation, the prime mover will not start when the decoder receives track power when auto-start is disabled. For analog mode (DC) operation, the prime mover will start when the decoder receives track power regardless of CV 114. Auto-start is enabled by def
Short version, assuming nothing has been changed from the default, read CV114, subtract 16, and put that value back in CV114. Now you have to hit the RPM+ function button to start the engine after power up.
Wouldn’t you subtract 32 ?
Mark.
It depends on what the OP wants to do. If he wants the press F5 (assuming default mapping) to start prime mover you would subtract 16. To have it start with speed step 1 would be to subtract 32.
Personally I use JMRI and take the math out of it. Makes program way easier.
Glad you posted this!
I was lost after the 1st paragraph of the previous post. That guy knows allot more than me about programming these decoders And his reply is probably easily understood by you and other more advanced DCC users. I read some of that in the manual and thats WHY I posted here hoping for an English interpretation.
Is the RPM+ function button the throttle wheel on the NCE Pro cab?
Ok so I want to subtract 32 so sound starts when I apply speed step 1.
I want to subtract 16 if I want sound to start when I push the Function 5 button on the controller.
Correct?
Yes.
For everyone else - the instructiosn say add 32 for automatic startup, or add 16 for startup on F5. They also say the “add 32” is the default. So I want 16, not 32 - that means I subtract 16. Or if you really must do it in 2 steps, subtract 32 to turn off that option, then add 16 to turn on the F5 startup option.
And remember they are always talking about the base value of the CV. You don’t just blindly add 32. You need to read the current value. If it is already 32 or higher, the option is on adn you can;t add another 32 to the total.
Again, this is just like CV29. Pick the value for each option you want, add them up and that’s how you get the total to plug in to the CV. It ISN’T hard, don’t overthink it.
ANd - why do you want this one to NOT start up when you turn on the power but you want the other loco with a loksound to come up as soon as you turn on the power?
ANd the absolute most silly option is the one where the prime mover doesn;t start until speed step 1 - why Soundtraxx even offers that is a mystery. Looks really silly to see a loco start creeping down the track and then the prime mover cranks up. IS it a hybrid loco, running on batteries and then the prime mover kicks in? Either power on with the track power or start with a function.
Thanks Randy.
I don’t want any locos to just come on when the system power is turned on or there would be a bunch of them starting up and idling even if they are not in use. I agree with your point that there should be a function key to start the prime mover and not a speed step.
As always you make the information clear and understandable. Thanks.
I read CV114 and subtracted 16 but it still ones on with layout power. Does this decoder need to be programmed, shut of and then re-energized to take the settings?
Dunno but all you would have to do is tilt the loco to one side so the wheels on one side break contact with the rail.
I’ll try that
Tsunami has several decoder versions and associated manuals. This loco was purchased new a few months ago. How can i tell which decoder is in it?
Ok found it on the Athearn site, it’s a Tsunami 2. The manual says:
So I subtracted 16 from the default value. Is this what you were talking about the manual being wrong?
When I get home later I will post the original value and the value after I subtracted 16. See if it looks correct.
That says nothing different that the previous information about adding 32 or adding 16.
I get that ordinary people may understand the idea of adding 16 or some number, but you can’t blindly do this without knowing the starting point. As I explained in the other thread, adding values like 4, 16, 32, etc. are just turning certain bits on. If it’s already on, adding another 16 would change a completely different bit. According to the original information, the bit controlled by the value of 32 is already on as the default. You don’t want auto startup but you do want the interlock as controlled by the 16 value. Adding 16 to the default value would turn on BOTH bits - who knows with these things, maybe that’s what it wants. Subtracting 16 turns OFF the bit for 32 and turns ON the bit controlled by 16. Subtracting 32 from the default turns off the bit controlled by 32 and makes no other change. Adding 16 after that then sets the bit controlled by 16 on. SO - same thing as just subtracting 16 in the first place.
What really matters is exactly what combination is required. The instructions orignally posted suggest that the 16 and 32 bits are mutually exclusive - you want one or the other. However, if subtracting 16 did not give the desired result - either the original value was less than 32, OR the actual setup required is both bits need to be set.
Ok so the CV 114 value that was programmed into the locomotive when I got it was a value of 103. I subtracted 16 which made it 87. The sound still comes on when the layout is powered up.
Please correct me if I’m wrong but if the default value of CV 114 is 103 and the interlock feature is OFF by default then you shouldn’t you ADD 16 to this value to give a value of 119 to turn on the feature?
Joe
A vaue of 103 has auto-start turned on. So to get rid of that, subtract 32. Then add 16 to turn on the notch+ startup. So, same thing as just subtracting 16.
Now, if the instructions are misleading, as I mentioned in my last post, you can try adding 16 and making it 119. That per the documentation would have both auto start and the manual start on, which would seem to be contradictory. But what do I know, there are reasons I won’t use Tsunamis…
Well turns out that OEM decoders use a different CV than their other decoders. Its actually CV116 for OEM decoders not 114.
this is from User Guide found here. on page 44.
Engine Auto-Start
When active, the Auto-Start feature starts up the prime mover sound automatically whenever the decoder is powered up regardless of whether or not it is addressed by the user. In this manner, the locomotive will begin producing sound without any user intervention. To use the Auto-Start feature, first determine the baseline value for CV 116 based on your choice of manual (setting of 0 or 16) or automatic engine notching (settings 1 through 15). Then to enable auto-start, add 32 to the setting in CV 116.
Example: We want to use automatic notching with a one notch increase for every eight speed steps. From the section under ‘Engine Control’, we determine the base setting for CV 116 to be 8. Then to enable Auto-Start, we add 32. Thus, CV 116 is set to: CV 116 = 8 + 32 = 40. Set the CV to something between 1 and 15 and the primer mover should
So if you set CV 116 to a value between 1 and 15 it should not start up until you select the locomotive. So typically 1 notch for every 7 steps is pretty normal for me. So if you set CV 116 to value a of 7 you should get automatic notching
So this whole thread was based on #FAKEInstructions, who woulda thunk? [:S]
